Gen 4 JDM info display
03 Jul 2025 16:32 #261123
by Mikeyboy
Gen 4 JDM info display was created by Mikeyboy
Hi all,
im considering buying an imported Gen 4 jimny ,
is there anyone in the U.K. that can recode the info display to English .
appologies if it’s been asked before,
hope you can help.👍
hope you can help.👍
03 Jul 2025 20:19 #261128
Replied by mlines on topic Gen 4 JDM info display
I understood that Jimny _Imports ( see Instagram) were able to offer it thorough a deal I introduced them to.
I am not sure if they off it to purchasers from other suppliers
The following user(s) said Thank You: Mikeyboy
04 Jul 2025 07:57 - 04 Jul 2025 10:24 #261130
by Motacilla
Replied by Motacilla on topic Gen 4 JDM info display
Is it necessary to remove & replace the instrument panel with an export-market unit, or is the language change done with just a firmware update?
(I ask because I would like to get my hands on any old instrument pod units that are being discarded, regardless of regional coding.)
Last edit: 04 Jul 2025 10:24 by Motacilla.
05 Jul 2025 09:55 #261135
I understand you can replace the JDM one with a UK one and it basically works. However not all the functions/lights work.
Therefore the best way is a firmware upgrade that mixes/matches functionality
05 Jul 2025 13:34 #261136
by Motacilla
This is very interesting.
So, without asking for more detail than you might want to give, is it correct to infer from what you said that the ECU can receive updated programming? Or is it the programming of the instrument pod that you are referring to?
07 Jul 2025 14:42 #261144
Hi,
Its a re-flash of the dashboard firmware, not the ECU
Time to create page: 2.095 seconds
