BigJimnyMeet 2024
New SJ owner - couple of q’s
- lesgrandepotato
- Elite Member
- Thank you received: 54
10 Sep 2023 15:04 #250728
by lesgrandepotato
Replied by lesgrandepotato on topic New SJ owner - couple of q’s
Bit of progress to report! Struggled with the Aisin carb, blew it through with the airline. Replaced the vacuum hoses. Just could not find a stable idle.
Ended up soldering up the loom behind the fuse box to sort the head lights out.
Went for a Mot… failed… Excessive brake travel. Poor emissions, no side repeaters and head lamp aim.
Got the garage to aim the lights. No surprise it was cross eyed. I’d made no effort to sort it.
Seats and harnesses put in, bit of a fiddle with some 25mm flat bar onto the original seat rails.
Got up to 40mph on the way to the test. Brakes interesting. Badly lacking power.
Tried 4lo down the track home. This is good! Seems to be able 1mph per 1000rpm. Crawls down dead slow, should be fine for our baby tyro trials!
Lack of free wheel hubs means it’s seems easy to get locked up in 4wd with out rolling back to release the drive line.
So busy weekend this weekend found a colour tune and sorted the mix and idle.
Set the float heights, carb full of water… so drained and added fresh fuel!
Finalized with the bum Dyno up the track up the hill. It’s not exactly rapid!
Hope to get a test tommorow and see if we can find 5th gear and 55mph.
Oh yes and the final bit, laid down the graphics on the bonnet - loving it!
- lesgrandepotato
- Elite Member
10 Sep 2023 15:53 #250729
by lesgrandepotato
- lesgrandepotato
- Elite Member
11 Sep 2023 11:34 #250750
by lesgrandepotato
We have a ticket! Now for a week of driving to shake it down before the NL4x4 event at the weekend where we might just get it a bit dirty
- Thank you received: 479
11 Sep 2023 15:01 #250753
Replied by Soeley on topic New SJ owner - couple of q’s
Great news!
- lesgrandepotato
- Elite Member
13 Sep 2023 17:09 #250791
by lesgrandepotato
14 Sep 2023 06:49 #250801
Looks awesome!
- Thank you received: 333
14 Sep 2023 08:02 - 14 Sep 2023 08:05 #250802
Replied by yakuza on topic New SJ owner - couple of q’s
I think I have a copy of the German TUV or German Suzuki papers saying it is allowed to drive without the doors as long as there is a rope or chain preventing passengers to fall out.
Not sure if these help in Norway or in the UK but still I will keep them in the glove box when/if I drive without the doors. My door bolts need some serious persuasion to loosen but yours is easy to remove
Love driving without the doors, must be done with caution of course.
Looks awesome, and I know first hand it is awesome to drive a SJ as well. Good and hard work making this a great car, You really deserve the enjoyment now!
Last edit: 14 Sep 2023 08:05 by yakuza.
The following user(s) said Thank You: lesgrandepotato
- lesgrandepotato
- Elite Member
14 Sep 2023 13:48 #250812
by lesgrandepotato
Cheers Yakuza! I’ll be making a set of cut down half doors once I’ve got my welding mojo back. Given I live in the north of a rainy country there is little rush as we head into autumn!
- lesgrandepotato
- Elite Member
18 Sep 2023 10:59 #250864
by lesgrandepotato
Out for a play at the weekend with NL 4x4 club
- lesgrandepotato
- Elite Member
10 Oct 2023 16:07 - 10 Oct 2023 16:07 #251329
by lesgrandepotato
Well we’ve had a view trips out and I’m getting the hang of it now after the Jimny.
Things escalated slightly when went to view a local one with a mate.
Both K reg and the chassis numbers are 19 apart… so probably the same day build!
After flooding the air box at Dalton dirty martini has gained a snorkel and a couple of hundred miles have got the tune on the Weber much better and sorted a few electrical niggles out.
Finally fitted the new doors today. So Dirty is officially rust free and no visible repairs. Not bad for a 30 off year old truck. Still need to paint the bill bars and mop the paint but it’s ok for now.
However the spare tyre is dead, and the drivers front has a slow puncture, and the rest are showing a few cracks and bits of battle damage….
So the question is what do I go for? I’m on 215/75 LT’s at the moment. It’s got a 2” OME lift on it. I’m minded to go a little bigger… but that’s new rims as well I suspect…
Should I be looking at 235/75’s (circa 29’s) or 30’s? I’ve got the 4:16 transfer case so either a viable. Planning on keeping stock bumpers etc at the moment.
Any sage advice? Any interesting rims apart from steel Modular’s?
Last edit: 10 Oct 2023 16:07 by lesgrandepotato.
10 Oct 2023 18:32 #251330
by jlines
Replied by jlines on topic New SJ owner - couple of q’s
I like Weller wheels on SJs especially in white.
- lesgrandepotato
- Elite Member
28 Oct 2023 19:33 #251848
by lesgrandepotato
