New SJ owner - couple of q’s
- Thank you received: 1767
- Thank you received: 333
So the question is what do I go for? I’m on 215/75 LT’s at the moment. It’s got a 2” OME lift on it. I’m minded to go a little bigger… but that’s new rims as well I suspect…
Should I be looking at 235/75’s (circa 29’s) or 30’s? I’ve got the 4:16 transfer case so either a viable. Planning on keeping stock bumpers etc at the moment.
Any sage advice? Any interesting rims apart from steel Modular’s?
What size tyres on your follower there?
The front bumper can be moved forward to fit larger tyres. Not sure you would do this on yours, but I just bent the frame tubes forward a bit to make room for up to 31" and still using the original bumper. Also possible to cut or better relocate the bumper brackets a bit forward and drill new holes to fit 235 and a bit more.
With the "410" high range as the 4.16 case should provide, you could go up to 31" but then you would need alot of cutting in the fenders and some wider flares and wider 8" wheels with ET20. With 235 on either stock or 7" ET0 (or ET10 if your go up to 30") wheels it would fit better inside the original wheel wells. 235 BFG MT on my SJ410 fit just great on the Jimny alloys.
235's on stock wheels is probably out of the range on what is recommended but I have run that alot and never seen any excess wear or anything.
- lesgrandepotato
- Elite Member
- Thank you received: 54
Give it a few days… they are on the way. 15x7 ET0I like Weller wheels on SJs especially in white.
- lesgrandepotato
- Elite Member
- lesgrandepotato
- Elite Member
- lesgrandepotato
- Elite Member
- lesgrandepotato
- Elite Member
I’ve been trailing a chain of smoke after a sustained crawl in low ratio, and I’d assumed it was just hot oil and poor valve guide seals.
Thinking about it yesterday it was gently puffing white smoke which. I’d mostly ignored as being mist.
I’m wondering now if the servo seals have gone. Anyone got a method to diagnose?
