BigJimnyMeet 2024
New SJ owner - couple of q’s
- lesgrandepotato
- Elite Member
- Thank you received: 54
29 Jul 2023 16:54 #250030
by lesgrandepotato
Replied by lesgrandepotato on topic Re:Re:New SJ owner - couple of q’s
- Thank you received: 333
30 Jul 2023 11:18 #250042
Replied by yakuza on topic Re:Re:New SJ owner - couple of q’s
Love the progression. And all the good work.
- lesgrandepotato
- Elite Member
30 Jul 2023 18:38 #250054
by lesgrandepotato
- lesgrandepotato
- Elite Member
01 Aug 2023 13:00 #250070
by lesgrandepotato
Well the Mot is booked for Thursday… just need to reassemble it! Only major job really is setting the body mounts a final time and popping the dash in
- lesgrandepotato
- Elite Member
01 Aug 2023 19:50 #250076
by lesgrandepotato
01 Aug 2023 22:23 #250078
Should go into the center socket straight behind the center of the speedometer. Wiggle it?
- lesgrandepotato
- Elite Member
02 Aug 2023 13:22 #250085
by lesgrandepotato
Found the old one…. Seems that it screws on… so there must be two types of speedo cable for different yearsShould go into the center socket straight behind the center of the speedometer. Wiggle it?
- Thank you received: 653
02 Aug 2023 15:18 #250087
Replied by jackonlyjack on topic Re:Re:New SJ owner - couple of q’s
Is the square drive part same size has one removed
If the square fits could you use a jubilee clip to hold the outer in place
- lesgrandepotato
- Elite Member
03 Aug 2023 08:58 #250097
by lesgrandepotato
Failed at the first hurdle! Well the incline at the end of the drive…
So it seems that we have a running under load issue. It idles well, the accelerator pump jets are good.
But if you rev it up then it goes up with the (pump jets) then falls away. So I guess we aren’t transitioning to the secondary or main jets….
It’s a pretty complex looking beast the carb. Does a service / test manual / procedure exist?
When I rev it looking down the barrels then I don’t see the secondary move? Would that be expected? It’s not under load but it’s hitting 5k rpm so I kinda thought it would pull open?
- lesgrandepotato
- Elite Member
03 Aug 2023 19:56 #250107
by lesgrandepotato
So I’ve pulled the carb. I’ll need a rebuild kit. It looks somewhat complex. But that’s just a bunch of simple stuff nailed together.
Where are we going for a decent Aisin 83020 kit?
- lesgrandepotato
- Elite Member
06 Aug 2023 18:01 #250124
by lesgrandepotato
Bit of progress to report. Made and adapter in on the lathe to allow the speedo to plug onto the threaded boss.
finished stripping the bullbar and got that into primer.
The wipers have been hit and miss. So pulled the motor and improved the earth. Better ish! So folded the screen and tried again. Bugger! The wiper rack in the centre is so seized it’s spinning its mounts. No wonder the paint was cracking on the outside. Fresh rack on its way from India…
Pulled the carb apart. Replaced 14! Vac hoses and blew it out with compressed air. That’s got it running better. Spent some time setting the timing and then tried to get a decent idle. It’s getting better. Idle mix was way off and it’s less hunting than it was.
Holiday time soon, so progress will be impeded… hopefully the new seats arrive from Italy this week….
- lesgrandepotato
- Elite Member
09 Aug 2023 17:22 #250185
by lesgrandepotato
Time to create page: 0.225 seconds
