4x4 not engaging
- doncarlyon
- Visitor
Just take the hubs off (torx bolts) the centre part is spring loaded, put them into the locked position, bolt them back up and pull the pipes off the hub.
Ideally you want to block off where the pipes were connected to the hub to stop any muddy water getting in.
Look here - www.bigjimny.com/index.php?option=com_co...drivechain&Itemid=37
- Rswo
- Visitor
doncarlyon wrote: No need to buy anything!
Thanks, therefore when this is done its in 4 wheel drive therefore u would then need to reverse this action ever time you then go onto the open road, is that right?
As a said not the brightest spanner in the box when it comes to DIY
- doncarlyon
- Visitor
Normally when you select 4wd the vacuum system is triggered to activate the front hubs, this wont happen anymore as they are already selected / activated.
The difference is that in 2wd, as the front wheels are being pushed along they are turning the drive shafts and the diff and the front prop which will add a small amount of drag, wear&tear, etc. but I cant see it being an issue. And the drag / mpg difference isnt even noticeable.
- Rswo
- Visitor
- Rswo
- Visitor
Replace all the vacuum piping and hope that resolves the issue
Manually lock the front
Or
Fit a set of manual locking hubs From Bits4Vits
Looking at this and other forums There seems to be a majority going for The third option.
What does everyone think, need to get it sorted Asap
- goatboy
- Visitor
For me I felt I could have spent £30+ on replacing the vacuum piping and it still not work, so biting the bullet and spending the money on the manual hubs I know will work was the best option for me.
All depends on if you have a spare £160 floating around. If you do then go for it!
- doncarlyon
- Visitor
- 247sniper
- Visitor
Anyone know
Steve.
- darthloachie
- Visitor
also jimny bits sells the new ones as well
- jo king
- Visitor
- 247sniper
- Visitor
darthloachie wrote: keep your eye on ebay as they appear on there from time to time and go for about £65 but make sure you get the cone washers as well and you'll still need martins adapter kit
Does jimny buts sell the pipes?
Any ideas o dealer prices?
- jo king
- Visitor
Manual hubs are good and fixed hubs would give you less mpg plus premature wear of the front axle oil seals. Pneumatic hubs all the way for me
