Considering wax oil treatment,
- Roger Fairclough
- Thank you received: 210
24 May 2024 10:15 #256064
by Roger Fairclough
Replied by Roger Fairclough on topic Considering wax oil treatment,
Yes.
Roger
Roger
- Thank you received: 498
24 May 2024 11:54 #256065
Replied by Soeley on topic Considering wax oil treatment,
Your's might be a one-off Roger?
- Roger Fairclough
24 May 2024 13:25 #256067
by Roger Fairclough
As I said earlier, I am a pedantic sod and I don't like the colour of rust. Last year I removed the rear bumper, cleaned the small amount of dirt from the white painted body work and started coating it with bitumastic paint. There was no rust. I then painted the chassis rails and wheel-arch body- work. painted what I could see including the axle. I worked forward until I reached the "X" shaped crossmember. At this point I gave up because the thick coating of underseal was still in perfect condition. This year, weather permitting I will complete the painting because there is slight rusting on the front axle. I will be servicing Tonka from now on and that includes inspecting the body/chassis for rust. I realise that Suzuki will use this non sanctioned inspection to nullify any warrantee that may have applied but that does not bother me because the prevention is better than the cure.
The first SJ I nearly bought was covered in rust and corrosion because the owner regularly drove it in the North Sea in Northumberland ( I lived 20 miles north of Newcastle at the time ) and maybe the extreme rust on the earlier pictured example may have been due to similar treatment although that does not explain or excuse the lack of treatment on various parts.
Yes Soeley, I might have a good one. What they called in the sixties a "Thursday" car. Either that or the Gods of the Underseal smiled on me because I hadn't upset "you know who" lately.
Roger
Roger
- Thank you received: 20
24 May 2024 14:43 #256068
by Motacilla
Replied by Motacilla on topic Considering wax oil treatment,
I agree with Dr Robin and Busta that an undercoating job is a fairly extensive exercise if done properly.
I had Dinitrol done on the Jimny by a local one-man-show business. He had the Jimny for three full days, and I had to wait a month just for an appointment. He removed all the plastic exterior cladding and bumpers, masked off the working components of the chassis carefully -- and the chassis number stamping! -- cleaned and dried it, and got a nice even coating on. He also removed the three door cards and got the interior door bottoms coated -- I can almost guarantee there is not adequate factory protection in that area.
Downsides: First, Dinitrol stinks for weeks, like a can of spray paint exploded in the car-- SWMBO will complain. Second, the material takes some days to fully set up, especially in hot weather -- I ended up with some drips under one door when I parked in the hot sun before it had totally hardened. Third, the cost, but IMO for a long-term owner it is worth it-- someone planning to sell the Jimny in a year or two should probably not bother though.
Dinitrol, done properly, is extremely hardy. We have a lot of snow and associated road salt here on the high Baltic, plus a lot of unsealed roads in the countryside, and nobody here bothers with Waxoyl if that tells you anything about the relative merits of the two products. Just my observation, others may have different results.
- Roger Fairclough
24 May 2024 17:39 #256074
by Roger Fairclough
If you look at the post from Filipao concerning rear lamp protectors you get a good idea of the extensive underseal applied to the chassis rails. On Tonka, that finish covers the entire chassis rails.
Roger
Roger
- Thank you received: 600
24 May 2024 19:13 #256078
by facade
Replied by facade on topic Considering wax oil treatment,
Looks like it has been driven on roads covered in corrosive salt & grit, and then not carefully washed and dried to me.
A coat of lanoguard or clear dinitrol/waxoil would have prevented it.
![:) :)](/media/kunena/emoticons/smile.png)
- RumbleAndSway
- Premium Member
- Thank you received: 12
24 May 2024 19:41 #256079
by RumbleAndSway
Replied by RumbleAndSway on topic Considering wax oil treatment,
Celebrating 4+yrs of JB74 [SZ5] ownership by confessing to be a Lanoguard Moto Grease convert/advocate.
Couple of ramps, a brush & pot of LMG a deeply satisfying way to spend 45 minutes under the Jimny.
- Me and my Jimny
- Premium Member
- Thank you received: 7
17 Jun 2024 06:18 #256312
by Me and my Jimny
Replied by Me and my Jimny on topic Considering wax oil treatment,
I've tried lanoguard this year too and so far I'm impressed with the spray but not so much the grease.
I don't mind the idea of recovering regularly when it's so easy to cover it, it will make me clean and inspect more regularly too.
Too early to say how effective it is but for now it's nice to have black axles etc. instead of orange
17 Jun 2024 13:52 - 17 Jun 2024 13:59 #256315
by facade
A youtube video on Lanolin popped up in my clickbait feed
You can buy his mixture from www.rust.co.uk/shop/diy-vehicle-restorat...n-penetrator-primer/
Crikey! what a long link!
I'm inclined to get some of the Corrolan pure underbody wax and warm it up before spraying with the waxoil gun.
I'm not over keen on a bio-degradeable product inside the chassis though, I'll stick to Dinitrol for cavities.
(Watch out, the prices are all ex-VAT)
Last edit: 17 Jun 2024 13:59 by facade.
Time to create page: 0.130 seconds
