Considering wax oil treatment,
21 May 2024 08:27 #256025
by Porthos
2020 SZ5
Considering wax oil treatment, was created by Porthos
Has anyone gone down the wax oil treatment road. Mine can be done for around £500 locally. Is it worth doing?
2020 SZ5
- Thank you received: 438
21 May 2024 08:54 #256027
Replied by DrRobin on topic Considering wax oil treatment,
Most people who intend keeping their Jimny go for underbody treatment. In addition to Waxoyl there is also Dinitrol and Lanoguard.
I am considering Dinitrol for my Jimny, but make sure the place doing the job properly cleans and dries the underneath first, this is usually a 2 day job.
Robin
Robin
- Thank you received: 509
21 May 2024 11:16 #256033
Replied by Soeley on topic Considering wax oil treatment,
I believe Lanogaurd and Waxoyl need redoing every 12 to 24 months. Dinitrol is much harder wearing, is jetwash proof and only needs touching up if you manage to scrape some off, on rough ground.
When I had mine done in 2019, the garage offered a free anual inspection and touch up, if required
- Thank you received: 1801
21 May 2024 19:25 #256040
Replied by Lambert on topic Considering wax oil treatment,
I use waxoyl and am aware that it needs a top up every year on high abrasion surfaces like the leading edges of axles and in the wheel Wells but that's to be expected on a working vehicle. The rest is as good as when I applied it 3 years ago.
22 May 2024 11:32 #256048
by Busta
Replied by Busta on topic Considering wax oil treatment,
That depends on what sort of job they are going to do. To do it properly they will need to remove the wheels, arch liners, headlights, both bumpers and the exhaust backbox. £500 would be reasonable for an extensive job, but expensive for someone to quickly spray some waxoyl around the bits they can see.
I'd also recommend something better than waxoyl if you're not planning on topping it up every so often.
- Roger Fairclough
- Thank you received: 210
22 May 2024 12:26 #256049
by Roger Fairclough
Replied by Roger Fairclough on topic Considering wax oil treatment,
The Gen.4 has extensive underbody treatment and a 12 year anti-corrosive treatment. This needs a check every a2 months but my local main agent told me that Suzuki would accept the stamp of a reputable dealer if I didn't want to pay £40-50 at the Suzuki dealer.
Last year I started to paint the underbody with bitumastic paint but gave up half way along when I saw how thick the Suzuki protection was. I might finish it this year, primarily because there is a small amount of rust on the front axle. It's nothing to worry about, but I am a pedantic sod and I don't like the colour of rust.
Roger
Roger
- Thank you received: 80
22 May 2024 18:38 - 22 May 2024 18:38 #256051
by lightning
Replied by lightning on topic Considering wax oil treatment,
After four years our Gen 4 still looks new underneath. l did spray everything l could get to, with a clear wax product to prevent surface rust on things like suspension parts.
Last edit: 22 May 2024 18:38 by lightning.
23 May 2024 15:18 #256058
by Porthos
2020 SZ5
Replied by Porthos on topic Considering wax oil treatment,
After considering the comments submitted, I may just go for a light touch approach because of the seemingly sound Suzuki coatings. I may stick with waxoil as I've used this to good effect on past vehicles. The kits availble to do this are reasonably priced and affordable to be able to do this approach more frequently. I just have to tap a mate of mine up to be able to borrow his ramps. Thanks for your comments.After four years our Gen 4 still looks new underneath. l did spray everything l could get to, with a clear wax product to prevent surface rust on things like suspension parts.
2020 SZ5
23 May 2024 18:55 - 23 May 2024 18:56 #256060
I have taken these screen shots from a Facebook group I'm on.
3 year old Gen4 with 20,000 miles on the clock.
I must admit, I didn't see any thick protection under mine before I had it done.
*Not my Jimny*
*Not my Jimny*
Last edit: 23 May 2024 18:56 by Soeley.
24 May 2024 03:26 #256061
I wouldn't be happy either if that were mine or indeed if I were looking to buy it.
- Roger Fairclough
24 May 2024 07:57 #256062
by Roger Fairclough
The pictures clearly show the underseal but also show the areas that have been missed, and this is clearly unacceptable. If it was mine, I would question the dealers attitude to the problem as it should have been noted at the yearly inspection. This is assuming that it was serviced by a Suzuki dealer!
Roger
Roger
24 May 2024 09:40 #256063
by Busta
Roger, are you suggesting that yours has underseal in the areas that have been "missed" here?
