Re:Commercial {LCV} Jimny on the road
03 Jul 2023 12:03 #249686
Replied by mlines on topic Re:Re:Commercial {LCV} Jimny on the road
Ours is known as the dog wagon/shopping trolley.
It excels on this role, out dogs love the space
Sent from my motorola edge (2022) using Tapatalk
The following user(s) said Thank You: Bob1050
04 Jul 2023 11:03 #249700
by Bob1050
Replied by Bob1050 on topic Re:Commercial {LCV} Jimny on the road
According to this man it's an easy job - although I'm leaving mine in place as I quite like it. Have taken a look at the video and also had a look at the car/cage and it looks like the Average Joe could undertake the job with little problem!
04 Jul 2023 19:45 - 04 Jul 2023 19:49 #249712
by lightning
Replied by lightning on topic Re:Commercial {LCV} Jimny on the road
Last edit: 04 Jul 2023 19:49 by lightning.
- Roger Fairclough
- Thank you received: 210
07 Jul 2023 13:09 #249777
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Commercial {LCV} Jimny on the road
I watched and listened, to the video from Bob 1050 concerning removal of the guard from his commercial Jimny and I was surprised as to the amount of noise generated when he closed the doors - side and rear - in comparison to my own Gen.4. Yes, I have fitted a sound reduction kit and yes it has made a big difference but hearing that metallic clang reinforces my view that a decent sound reduction kit will work wonders.
Roger
Roger
09 Jul 2023 15:26 #249796
by lightning
l've never had an issue with noise in our SZ5. Also l've not noticed any door clanging when slammed.
Noise levels are fine unless you drive it flat out, which we never do.
Best cruising speed seems to be 65mph
- Roger Fairclough
09 Jul 2023 21:52 #249798
by Roger Fairclough
I based my comment on listening to the sound as the doors on the LCV being closed and comparing it with my own SZ5 which has sound deadening panels applied to various areas. I am still convinced that the panels have made a considerable reduction to generated noise levels.
Roger
Roger
17 Jul 2023 13:04 #249892
by facade
I did the opposite, and fitted a transfer case guard.
This does a brilliant job of reflecting all the whiny whirry bearing & chain sounds up into the car!
My solution was to stick a big piece of that (supposedly) fire resistant closed cell sound deadening inside the guard, and it reduced the noise from "catastrophic gearbox failure imminent" to "is there any oil in it?" which will have to do.
Replied by facade on topic Re:Commercial {LCV} Jimny on the road
They will.I based my comment on listening to the sound as the doors on the LCV being closed and comparing it with my own SZ5 which has sound deadening panels applied to various areas. I am still convinced that the panels have made a considerable reduction to generated noise levels.
Roger
25 Jul 2023 09:18 #249988
by Grizzlie
Replied by Grizzlie on topic Re:Commercial {LCV} Jimny on the road
It is removeable entirely, and segmentally, just a few bolts. However, your local laws may not allow that. Mine require the cage to be in at all times, although common opinion is that the average law officer wouldn't take note. However, yearly car technical/safety inspections do take note as many are recorded.
The cage is also moveable in its entirety back one stop/mounting hole. You can get more reclining room this way at the expense of trunk space.
I've grown to like the cage. I 3d printed hangers from Printable and have a hat, a knite, and other doodads on it. Also, it has come in handy packing as I can literally top off the trunk with luggage.
It's only noisy when things clang on it. But I can understand that with no rear seats that there's much less deadening of whatever sounds do arise from the back
Time to create page: 0.149 seconds
