Turbo M16A Jimny
- Motleycrew
Topic Author
- Elite Member
- Thank you received: 23
06 Mar 2022 17:50 #242163
by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Tbh what I know changes by the hour! Steep learning curve but rewarding
- Motleycrew
Topic Author
- Elite Member
06 Mar 2022 18:39 #242164
by Motleycrew
Did most of the wiring today, ECU connector 90% complete. Have ended doing it all myself and it’s pretty straight forward. Definitely recommend the online course by HPA (high performance academy) I did the wiring fundamentals course and it’s been invaluable. Also wired the coolant and air intake temp. Will get a auto electrician to double check at the end as I darent risk frying the ECU.
- Motleycrew
Topic Author
- Elite Member
06 Mar 2022 18:54 #242165
by Motleycrew
Took the idle control valve off (actually used a mallet and chisel to remove the connector and solenoid as I didn’t have a bit for the Japanese star bit. Then unscrewed the housing which was a absolute pain as the intake manifold headers were obstructing the screws. Will try a see if a local machine shop can make a blanking plate.
- Motleycrew
Topic Author
- Elite Member
10 Mar 2022 14:25 #242225
by Motleycrew
Plate made
- Motleycrew
Topic Author
- Elite Member
12 Mar 2022 17:29 #242273
by Motleycrew
Wired up relays and loosely put idle control plate as I am waiting for sealant to arrive. Going to buy a cheap heat gun to shrink wrap all these connectors
- Motleycrew
Topic Author
- Elite Member
17 Mar 2022 17:41 - 17 Mar 2022 17:42 #242365
by Motleycrew
Very boring update that the silicone finally arrived. Car is booked into dyno for 4th April. Will plug in Ecu and configure some of it when I am feeling brave. Figured I can remove the fuse for the main relay and also the fuse that does the coils and fuel pump. This means I can tell the ECU what auxillary output is each relay. This avoids all these things just turning on as the ECU would just ground them. Not sure if the fuel pump would want to be primed that long. I am using the 4x4 solenoid wires for the ECU power.
Last edit: 17 Mar 2022 17:42 by Motleycrew.
Time to create page: 0.225 seconds
