Turbo M16A Jimny
02 Apr 2022 14:06 #242687 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
sadly the jimny arches dont have room above for this but you probably could put them on the Mr2
TEIN UK LIMITED | Products | EDFC ACTIVE
02 Apr 2022 14:26 #242688 by Motleycrew
This is Teins detailed product description for the Jimny. They do the Gen 3 and Gen 4.
uk.tein.com/product/street_advance_z4.html
The following user(s) said Thank You: Scimike
02 Apr 2022 19:36 #242691 by Motleycrew
found this cool video of a Jimny event in Japan:
TOP of JSTC2021 (jimny-matsuri.com)
04 Apr 2022 18:27 - 05 Apr 2022 05:41 #242723 by Motleycrew
while I wait to hear how the Jimny gets on, I have been thinking of a few supporting modifications that will help make the car more reliable.
first one which I will do is fit a electric water pump.  Davies Craig Electric Water Pumps (EWP) Information .
there are three ways to install it, which the link explains in detail, I will probably go with removing the old water pump impeller and leaving the housing installed and then by passing the pully completely. I will also remove the mechanical fan and put a electric one in. This means it will keep cooling the engine whilst its off and dump much more heat at idle.
The second will be putting either a secondary inline fuel pump or a intank one. Been thinking about this one.  Walbro GSL392 Inline Fuel Pump 255LPH HIGH PRESSURE (universal external pump) (walbrofuelpumps.com)
There are formulas to figure out the flow rates, but I believe the current Jimny one is 100 L/H which will max out about 170 bhp which is bad as I want to surpass that and also have lots of headroom. The walbro would be a booster at 255 L/H keeping enough flow to well past the stock engines boost tolerance. I may also get a boost referenced fuel pressure regulator, this video explains it all   (286) HOW and WHY to upgrade your FUEL PUMP and INJECTORS - THEORY + PRACTICE - Project Underdog #13 - YouTube
Last edit: 05 Apr 2022 05:41 by Motleycrew.
22 Apr 2022 16:18 #243059 by Motleycrew
The garage has run over with other jobs but I can announce that it is running. They said they had difficulty figuring out the trigger wheel pattern. The ECU has a inbuilt Oscilloscope that reads the wave pattern coming back from the crank sensor. Apparently its a random waveform and Link technical support ended up helping to decipher it.
Jimny will be on Dyno next week.
22 Apr 2022 16:23 - 22 Apr 2022 16:23 #243060 by Motleycrew
he said it runs like a little sowing machine...not sure if thats good or bad thing!
probably because of the sound of the timing chain?!
Last edit: 22 Apr 2022 16:23 by Motleycrew.
Time to create page: 0.243 seconds
