Turbo M16A Jimny
22 Apr 2022 16:33 #243062 by Riccy
Replied by Riccy on topic Turbo M16A Jimny
I should have mentioned there might be issues with the trigger wheel pattern. I encountered similar issues as well as noise on the wiring to the ecu from crank sensor. New wiring cleared up the signal and the crank pattern turned out to be the same as for a subaru I believe. My dyno guy started with a map for a swift sport and went from there to smooth it all out.
Sewing machine noises is good. Its a combination of timing chain and injectors dispensing fuel amongst the other moving parts there. Your new ECU can probably play tunes with the injectors as a test routine somewhere in its software :laugh:
The following user(s) said Thank You: Motleycrew
23 Apr 2022 12:31 - 23 Apr 2022 14:33 #243092 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
thanks, I did actually mention it was a Subaru one, which I must of read from one of your posts in the past. I called the tuner up about a year ago as i was planning the project and was concerned that I couldnt find the exact trigger pattern but he mentioned that he could figure it out easily but sounds like he had a nightmare going back and forth between Link technical support
Last edit: 23 Apr 2022 14:33 by Motleycrew.
01 May 2022 18:11 #243198 by Motleycrew
Jimny will go on dyno Tuesday apparently… but I have got a short video of it running.
The following user(s) said Thank You: Lambert, Soeley, Old Neil
28 May 2022 07:23 #243469 by Keithy
Replied by Keithy on topic Turbo M16A Jimny
so today I picked up the custom manifold and downpipe
That is one pretty manifold!
30 May 2022 14:53 #243514 by Motleycrew
So I am still waiting for the car! Have been promised  either tomorrow or the following day. They have been stalling me all this time, it’s been unbelievable tbh. Will update when I get it. Just got quoted insurance for £400 fully comp with the engine declared too. You would only know the engine was different by the engine code but rather be legit and cover myself.
30 May 2022 15:13 #243516 by Scimike
Replied by Scimike on topic Turbo M16A Jimny
True, and possibly the fact you bang your head on a large turbo as you attempt to read the number....
