Turbo M16A Jimny
20 Feb 2022 12:43 #241936 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Taken all the wires I need for the ECU. It’s honestly quite straight forward so will save the cost of a auto electrician doing this time consuming, yet simple part.
20 Feb 2022 13:00 #241937 by Motleycrew
All of the wires that are still in the connector are redundant. They are from Devices like the EGR, OBD-2, the two oxygen sensors, old map sensor (new ECU has its own on board sensor) 4x4 etc
26 Feb 2022 16:05 #242063 by Motleycrew
Put crimps on the ECU wires today, also fitted Bosch coolant sensor and boost controller plumbing. Wideband 02 controller is fitted. Wires are all now in the cockpit.  Need to do some splicing and then I will be ready to connect the battery up and start configuring the ECU settings.
28 Feb 2022 19:32 - 28 Feb 2022 19:34 #242092 by Motleycrew
So I need to put a additional relay in between the main relay as it is currently always live and doesn’t go through the ignition switch. This means the ECU would re-power up after the ignition was off as it stops it’s ability to block the grounds. The Jimny ECU has a permanent power source so I guess it can manage the grounds when the ignition is off. Went to check out the relays and where to splice the new one and found the old terminals just fell out from corrosion. The old denso relays are intact themselves but the connecting block pins are green and eroded. I have just ordered new Bosch ones to re-wire them (fuel pump and main relay)
Last edit: 28 Feb 2022 19:34 by Motleycrew.
28 Feb 2022 19:55 #242095 by Motleycrew
after figuring out the Jimny ECU power wire is always live I had to look for a power source that goes through the ignition switch. Best I could find was the 4x4 controller. I can either tap it in the cabin or in the engine bay.
01 Mar 2022 05:12 #242101 by Lambert
Replied by Lambert on topic Turbo M16A Jimny
I'm sure you know this already but Jimny are negative switching. It's possible to use relays to reverse this as people do it for spotlight installation etc.
The following user(s) said Thank You: Motleycrew
Time to create page: 1.321 seconds
