Turbo M16A Jimny
12 Feb 2022 08:46 #241804 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Offset air filter added and a few better pictures of the setup in day light. The car is abit tired but I thought I could transfer this all over to a newer Jimny in the future.
12 Feb 2022 08:50 #241805 by Motleycrew
Side in picture
12 Feb 2022 08:54 - 12 Feb 2022 08:54 #241806 by Motleycrew
Going to cut a label up the 3 connectors for the new ECU most of it will be redundant. Spoke to the auto electrician who is a elderly family friend. I can do most of it myself, he will just check it over at the end
Last edit: 12 Feb 2022 08:54 by Motleycrew.
12 Feb 2022 10:02 #241812 by Martin416
Replied by Martin416 on topic Turbo M16A Jimny
Looks like it's all fitting nicely in the bay. You making it so you can unplug the new ecu wiring section incase you need to put a standard one back in?
SJ416 spi, 33s, Cage, Rocklobster
12 Feb 2022 16:23 #241823 by Motleycrew
That wouldn’t be possible to unplug and switch between the two as the new ECU connector will be using the Jimnys existing wiring. You could just take the wires out of the new connector and put them back in the old as I will leave the old connectors in situ. The new connector has 34 pins where as the Jimny has 72 on the three. I won’t be using all 34 pins. I have attached a picture of the Jimny ECU pin out. E17,E18
12 Feb 2022 16:37 #241824 by Martin416
Ahh no problem wasnt sure how it came together
Time to create page: 0.305 seconds
