Turbo M16A Jimny
22 Jan 2022 12:35 - 22 Jan 2022 17:24 #241399 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Oil filter sandwich plate that came with 3 blanked off ports. will use one for the turbos oil feed and maybe use another port for a oil temperature gauge.I probably should monitor the temperatures. If the oil starts getting to hot I will have to resort to installing a oil cooler. I put the oil return in the sump a few months ago
Last edit: 22 Jan 2022 17:24 by Motleycrew. Reason: Typo
22 Jan 2022 17:33 #241410 by Motleycrew
Will have to get this gauge pod from Japan.Fits 60mm gauges though so was thinking of getting HKS oil temp and boost gauge. This is the Ebay description if anyones interested:
Jimny Dual Pillar Meter Panel Gauge Pod TANIGUCHI JB43 JB23 1998-2018 from JAPAN
  • Dirtbird
23 Jan 2022 18:28 #241429 by Dirtbird
Replied by Dirtbird on topic Turbo M16A Jimny
That will be nice.
23 Jan 2022 19:22 #241432 by Motleycrew
This is the kit that HKS (japanese tuning company) made for the suzuki swift sport
Suzuki Swift Sport HKS bolt on turbo kit (tdi-plc.com)
That M16a engine has a compression ratio of 11.1:1
The compression of my non vvt liana is 9.7:1 which means it will be more knock tolerable.
hope this works in the real world though!
23 Jan 2022 21:21 #241441 by Martin416
Replied by Martin416 on topic Turbo M16A Jimny
This is looking like its going to be alot fun!
SJ416 spi, 33s, Cage, Rocklobster
  • Dirtbird
23 Jan 2022 22:19 #241444 by Dirtbird
Whole other level these builds are. Lads how do you get into the technology end of doing this, or where do you start with getting ecus to connect to sensors and make it work. Are places you can learn it?
