Turbo M16A Jimny
21 Jan 2022 21:02 #241376 by sniper
Replied by sniper on topic Turbo M16A Jimny
Hey guys,
i know this isn't about turboing or other force induction but I've found this 2013 s cross with a m16a vvt engine and I was wondering if I could just rip it out and put it in my 2006 vvt jimny? Or would I need an ecu, I'm looking for a bunch of the same answer cause I've had two guys tell me different things.
You need an 05' to 10' engine, the trigger wheels changed and post 10' engines will not run on earlier ECU's.... Suzuki Liana bolts straight in...
sniper
21 Jan 2022 21:08 #241377 by sniper
Can you send me some information on the pistons and rods? Do they come with all the rings etc. I might get a newer m16a engine and build it in the side
rzcrewgarage.com
sniper
The following user(s) said Thank You: Motleycrew
21 Jan 2022 22:38 #241384 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
Have been trying to decipher the wiring diagram, got the hang of most it. Pretty much all the wiring will be retained and the ECU will take the old ones place. The 4x4 vacuum module will be disabled and I will need to get manual front hubs in the future. I am going to use the vacuum hub line nipple from the inlet manifold and run a 3mm hose to the onboard map sensor to the ECU.
22 Jan 2022 09:16 #241395 by Motleycrew
Fitted vitara brakes a couple of weeks ago
22 Jan 2022 10:25 - 22 Jan 2022 17:16 #241396 by Motleycrew
This is the electrical hardware that cost me a small fortune. I decided to get a digital wideband controller as they are more reliable and enables closed boost control. The boost controller will keep tabs on the waste gate creeping open.
Last edit: 22 Jan 2022 17:16 by Motleycrew. Reason: Typo
22 Jan 2022 10:29 #241397 by Motleycrew
*analogue or digital wideband makes closed boost control possible. You can get away with a narrow band controller and have the dyno use there own wideband o2 sensor on a stick stuffed in the exhaust to map the car.
Time to create page: 0.188 seconds
