Turbo M16A Jimny
20 Jan 2022 21:02 #241332 by Scimike
Replied by Scimike on topic Turbo M16A Jimny
Interesting and thanks for sharing how it goes. Nice manifold
The following user(s) said Thank You: Motleycrew
  • Dirtbird
20 Jan 2022 23:36 #241334 by Dirtbird
Replied by Dirtbird on topic Turbo M16A Jimny
For the love of Saint Francis of Mesmertain, it will atomise all before it....
21 Jan 2022 05:01 #241337 by Lambert
Replied by Lambert on topic Turbo M16A Jimny
This is going to be exciting. Have you got stronger rods and pistons for it so you can run more than 5psi of boost?
21 Jan 2022 06:38 #241340 by sniper
Replied by sniper on topic Turbo M16A Jimny
Nice looking gear, I look forward to the build.... What ECU are you using, I'm am just about to order and any help would be appreciated...
sniper
21 Jan 2022 06:56 #241342 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
I went with a brand called Link because its the one that my local dyno is most familiar with . The model is called Monsoon. You just need to check the one you choose has the features that you require eg knock control, vvt or closed loop boost control and enough inputs and outputs. I found its more a case of seeing what is the most basic model in a company's range you can get away with as the prices start going up
21 Jan 2022 07:02 #241343 by Motleycrew
still all standard internals, would like to forge it but the cost is crazy. Would then also need to put a uprated fuel pump
Time to create page: 0.196 seconds
