Turbo M16A Jimny
21 Jan 2022 09:08 #241344 by Lambert
Replied by Lambert on topic Turbo M16A Jimny
Cheaper than a rod through the block I would have thought?
21 Jan 2022 09:20 #241345 by Motleycrew
Replied by Motleycrew on topic Turbo M16A Jimny
This engine can handle half bar of boost with standard internals. Been done a lot on Suzuki swifts. They actually put the liana engine in as it has a low compression ratio compared to the high compression ratio one in the Suzuki swift sport. Also I paid £280 for the engine plus abit cleaning the head up at the machine shop. Forging it will cost thousands, not to concerned about the engine.
21 Jan 2022 10:01 #241346 by sniper
Replied by sniper on topic Turbo M16A Jimny
I can source forged rods and pistons for £890 delivered if they are of interest....
sniper
The following user(s) said Thank You: Motleycrew
21 Jan 2022 10:20 #241348 by Motleycrew
Will keep that in mind thank you
21 Jan 2022 11:34 - 26 Jan 2022 19:11 #241355 by Motleycrew
Can you send me some information on the pistons and rods? Do they come with all the rings etc. I might get a newer m16a engine and build it on the side
Last edit: 26 Jan 2022 19:11 by Motleycrew.
  • CharterBoat
21 Jan 2022 14:17 #241358 by CharterBoat
Replied by CharterBoat on topic Turbo M16A Jimny
Hey guys,
i know this isn't about turboing or other force induction but I've found this 2013 s cross with a m16a vvt engine and I was wondering if I could just rip it out and put it in my 2006 vvt jimny? Or would I need an ecu, I'm looking for a bunch of the same answer cause I've had two guys tell me different things.
