Giving the Jimny a birthday
02 Apr 2021 09:53 #234189
by RainerK
Replied by RainerK on topic Giving the Jimny a birthday
02 Apr 2021 11:08 #234194
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Giving the Jimny a birthday
I was actually looking at these yesterday. Much better option than forking out a grand or so for a gas axe set up. I'm replacing most bolts with stainless, so hoping 'next time' won't be so bad. I'll definitely chuck one of those in my basket in future and give it a try.
02 Apr 2021 11:16 #234195
by RainerK
If you replace your bolts with stainless make sure to all grase them on the thread. Otherwise they seize up, almost for sure. And they usually have less strength so do not use them on structurally important places.
Maybe better are bolts that are properly galvanized.
02 Apr 2021 11:19 #234196
by RainerK
The (in my opinion only) advantage of a gas burner is that it can also heat up the outside and sometimes this is much better than heating from the inside.
02 Apr 2021 12:06 #234200
by Mike G
Well, I think it will have to be an addition for the toolbox as I can always pop over to my mates who has the gas axe if I get stuck.RainerK wrote: The (in my opinion only) advantage of a gas burner is that it can also heat up the outside and sometimes this is much better than heating from the inside.
- Roger Fairclough
- Thank you received: 217
02 Apr 2021 12:27 #234201
by Roger Fairclough
Replied by Roger Fairclough on topic Giving the Jimny a birthday
Also gas has the advantage of being able to braze.
Roger
Roger
Time to create page: 0.467 seconds
