Giving the Jimny a birthday
31 Mar 2021 17:51 #234148 by Mike G
Replied by Mike G on topic Giving the Jimny a birthday
Riccy wrote: A/C compressor can be tested by using jump leads. Put negative to the body and +12v to the small wire terminal. It should make the clutch plate pull in and engage when voltage present. Also check it spins freely when disengaged. Shims can be added to get it sitting nice
Thanks Riccy,
I might just do that, sure I'll have a few wires kicking around to use.
I have fitted the unit (plus condenser and pipes) back to the engine so that all the hose fittings are protected in the meantime.  Still don't have a 950 belt to put on as I have been running the A/C bypassed for years now.  I'm going to check the system holds a vacuum before I commit to spending more cash and do any more work on the A/C system tho.  Would be nice to have it back and running tho as the list of luxury extras on a Gen 3 is short enough as it is
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
31 Mar 2021 18:02 #234149 by Mike G
Scimike wrote: Hi Lambert / Mike,
Must admit the Recaros look good and as our Jumny is a "keeper" at some point I will need to replace or refubish the seats.
SO - What are the possible donar vehicles, Suzuki swift?
My refurbish option is these;-
www.theseatsurgeons.co.uk/shop/suzuki-jimny-leather-seats/
Yes a lot of money, but I've just seen a plastic G4 snorkel sell for a lot more, so by comparision cheap!
And I am worth it
The premium nappa is off my list  .  I couldn't tell you what seats fit. I did see a nice set of suzuki swift sport seats on ebay, but I didn't want to risk being left with a pair of seats I couldn't use as my garage space is at a premium just now.  They aren't recaros, but they look decent enough buckets to me, might be worth a punt unless anyone else knows different.  Worse case scenario, you re-list them on ebay.
I paid a bit much for mine £300, but I don't mind spending money on things I'm going to spend a lot of time in, like a bed, shoes and chairs.  But if you want to pay around the same for a brand new set from the seat surgeons, you'll probably be paying around the same as I did, minus the time spent cleaning fart particulate and bogies out of them.
Here's the link to the swift seats I saw:
Swift sport seats
The following user(s) said Thank You: Scimike
01 Apr 2021 20:38 #234173 by Mike G
Thursday 1st April
Jobs done:
  • Fitted vice to workbench to do calipers
  • removed seals, cleaned and painted calipers
  • removed seats and cleaned horrid looking grime off them
Had a couple of stuck bleed nipples in the calipers as I've not been servicing my brakes at all in the past 7 years, so had to take them to a mate with a gas torch to get some heat into the threads to remove them without snapping them off and causing myself unescessary heartache.  Which of course, wokred a treat! The spot cleaner that I ordered arrived today as I was working on the calipers, so I decided to get the seats cleaned as it was sunny (for a short while) and alternate painting callipers with cleaning seats to make two boring jobs a bit less mundane.
In the pics, the seats on the grass are dirty, the ones on the paving slabs are clean.
01 Apr 2021 20:47 - 01 Apr 2021 20:48 #234174 by Soeley
Replied by Soeley on topic Giving the Jimny a birthday
I didn't know Bissall made motorcycle helmets :)
Last edit: 01 Apr 2021 20:48 by Soeley.
01 Apr 2021 20:48 #234175 by Mike G
Soeley wrote: I didn't know Bissel made motorcycle helmets :)
New range available today only!
01 Apr 2021 20:55 #234177 by Soeley
Aww, that sucks!
Time to create page: 0.799 seconds
