Giving the Jimny a birthday
15 Mar 2021 23:19 #233750
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Giving the Jimny a birthday
I'm dreading the wire wheel now. There's a lot of previous underseal to come off and it takes forever!
15 Mar 2021 23:40 #233751
by Mike G
Monday 15th March
Jobs done:
I'll have to think about getting a bunch of new fasteners for the suspension components as it's about time I got that in a rolling state again. I also tried to remove the grease nipple from the drive shaft that slides on splines, but gave up on it as it was like warm chocolate...and as the shaft has already been painted, I didn't want to heat it up to remove it, bit close to the UJ bearings anyway. I decided to pack the splines with grease and put a new cover over it, but I made a boo boo and seperated both parts when of the driveshaft when cleaning it without marking its position first. Looks like I'll be removing and refitting the driveshaft at least 15 times now to find the correct balanced position Ah well, that will teach me for switching off my brain.
Jobs for tomorrow:
get back on the grinder and start prepping up the underneath of the body for its first coat of primer.
maybe put some paint on some parts
Jobs done:
- Welded on another sil plate and reenforced two rear points where the body gets jacked up
- removed front wings
- braced up the front and cut out the old slam panel
- cut back the rusty mess at the front and test fitted the new panel
- pressed in new poly bushes to the radius arms and a panhard rod
- put new ball-joints in steering and tracking rods. Cleaned up threads as these were shockingly bad.
Jobs for tomorrow:
16 Mar 2021 21:12 #233786
by Scimike
Replied by Scimike on topic Giving the Jimny a birthday
It's an amazing amount of work in a very short time. You appear to have tackled a Jimny with every conceivable rust spot in full swing, it's going to be amazing when it starts to come together.
Cant be that far from this turning point.
It's made me feel worn out just looking at the pictures. Good work.
- X8GGY
16 Mar 2021 21:21 #233787
If you're short of anything I try and stock all the nuts'n'bolts needed for suspension rebuilds - www.zookbob.com/bolts
Replied by X8GGY on topic Giving the Jimny a birthday
Mike G wrote: Monday 15th March
... I'll have to think about getting a bunch of new fasteners for the suspension components as it's about time I got that in a rolling state again. ...
16 Mar 2021 23:08 #233790
by Mike G
Thanks Scimike,
I'm about worn out myself working 7 days a week for 2 weeks now. Mind you, its been better than sitting around the house sedentary all day like I have been doing recently.
I'm starting to see some results from my labour. Hopefully within the week, I should have it back to a rolling (starting?) vehicle again. I didn't fancy buying another jimny as I've grown attached to this one, plus I passed the point of no return when I said yes to the rental of the shed. It was 'all in' or nothing once I'd started.
16 Mar 2021 23:13 #233791
by Mike G
thanks,
If I get stuck, I'll give you a shout. I think I have most stuff on order arriving. I've tried to be proactive along the way.
Time to create page: 0.420 seconds
