Giving the Jimny a birthday
31 Mar 2021 11:04 #234135 by Mike G
Replied by Mike G on topic Giving the Jimny a birthday
Yesterday 30th March
  • hot power washed jimny carpet and hung to dry
  • picked up fuel tank that was drying in a shed
  • modified ignis seats and test fitted
  • torqued body mount bolts to 60Nm
Courier arrived with a package today.  New (to me) recaro seats!  So I got busy and modified the seat adjustment bar on both.  Put them back together, tested the worked and then test fitted them.  Seems that the runners will need to be modified somehow to make them operate better as they are a couple of cm out at the rear.  I'll have to give the seats a clean as they are filthy, so I've ordered a stain cleaning vac. Torqued the body mount bolts, but left the front two and did them with a smaller ratchet as I didn't want to horse the bolt down and strip the thread out the captive nut of the new slam panel.
Today is raining, so I'm not going to bother with anything in the garage as it's full of junk at the minute and I can't get moved to work.  Rest of the week looks fine for getting on with things tho.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
31 Mar 2021 13:15 #234138 by Lambert
Replied by Lambert on topic Giving the Jimny a birthday
The recaros are the best modification after decent tyres.
31 Mar 2021 13:55 #234139 by Mike G
Have to admit, I had a seat in them whilst they were on the grass before I fitted them.  I think they will definitely improve the comfort factor.
31 Mar 2021 14:52 #234140 by Scimike
Replied by Scimike on topic Giving the Jimny a birthday
Hi Lambert / Mike,
Must admit the Recaros look good and as our Jumny is a "keeper" at some point I will need to replace or refubish the seats.
SO - What are the possible donar vehicles, Suzuki swift?
My refurbish option is these;-
www.theseatsurgeons.co.uk/shop/suzuki-jimny-leather-seats/
Yes a lot of money, but I've just seen a plastic G4 snorkel sell for a lot more, so by comparision cheap!
And I am worth it
31 Mar 2021 16:17 #234145 by Riccy
Replied by Riccy on topic Giving the Jimny a birthday
A/C compressor can be tested by using jump leads. Put negative to the body and +12v to the small wire terminal. It should make the clutch plate pull in and engage when voltage present. Also check it spins freely when disengaged. Shims can be added to get it sitting nice
Mike G wrote: Did a few jobs this weekend:
  • primed x4 and topcoated x2 on swivel joints
  • dismantled rusted A/C unit and cleaned it up.  No idea if it works, but it's back together again.  Perhaps a job for another day.
  • primed, painted and stone chipped fuel tank with gravitex
  • ordered stainless jubilees for fuel tank
  • made some brackets for the handbrake and ABS sensors on the rear
Just pottering away whilst the weather is good as my jimny now sits outside.
31 Mar 2021 16:56 #234146 by Roger Fairclough
Problem with the Gen.4 is that they have the central seat belt mount fixed to the seat.
Roger
Time to create page: 0.193 seconds
