Giving the Jimny a birthday
05 Apr 2021 16:39 #234266
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Giving the Jimny a birthday
Did a few jobs this weekend
- confirmed my AC gauge set was not leaking and identified a small leak on the AC system. However, could be due to the system not being used for so long, it's not sealing correctly. So I'll have to half charge it with dye and identify it.
- Drilled out ABS sensor bolts on front hubs and reclaimed the holes to be used again.
- Drilled out and retapped 2 bolts on the AC condenser mounting bracket
- kingpin bearings plus shaft seals renewed and hubs refitted to front axle
- wiped down plastics inside car as they were very dusty
- shampooed head liner inside car to remove unwanted 'welding scent'
- fabricated two more brackets for the ABS cable on the rear trailing arms
- fitted ABS sensor cable to front axle with p-clips
- partially fitted hub vacuum hose as I ran out of clips
- Thank you received: 1999
06 Apr 2021 03:17 #234272
Replied by Lambert on topic Giving the Jimny a birthday
Looking good.
07 Apr 2021 12:24 #234292
by Mike G
Thanks Lambert,
It's just taking forever to do the last jobs. Still waiting for the new arches, so can't do anyhting until I can see how the bumpers line up. In case I need to redrill them. This bout of snow the past few days has put a stop to work tho.
10 Apr 2021 08:02 #234367
Replied by jackonlyjack on topic Giving the Jimny a birthday
10 Apr 2021 18:28 #234377
by Mike G
Thanks Jack,
It's never going to be perfect, but it's nice to save a small fortune by applying some knowledge and getting a similar result to what I want. I've also enjoyed learning some new skills and techniques along the way. However, there's still a long ways to go yet as I've got to modify the front and rear bumpers to match the new arches, a lot of faffing around with filler paste and sandpaper unfortunately.
13 Apr 2021 22:42 - 20 Apr 2021 20:01 #234456
by Mike G
Jobs done over the weekend
too many to mention because I keep adding them on all the time I'll get some pics of what I've done as I usually leave the phone in the house to prevent distraction when working.
- secured the hub vac silicone hoses using my 3d printed brackets design
- secured brake and fuel lines using my 3d printed brackets design
- serviced brake calipers, painted them orange and fitted them to the jimny
- fitted steering rod and tracking rod
- realligned steering to centre steering wheel
- fitted steel wheels
- fabricated washers for interior components fitment to new boot floor
- fitted rear light clusters back on
- fitted plastic interior trim for rear
- fitted rear seats (seats aren't going in, but the plastic liner I have for the back sits on them)
- ran in and tie wrapped breather pipes for axles, g/box and t/box (still need to fit the manifold somewhere in the engine bay)
- painted slam panel with a coat of primer
Last edit: 20 Apr 2021 20:01 by Mike G.
Time to create page: 0.244 seconds
