Giving the Jimny a birthday
12 Mar 2021 23:45 #233696
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Giving the Jimny a birthday
Friday 12th March,
Jobs done
This leaves the boot floor and slam panel as the only welding needing done. Hopefully I can get these done this weekend and start prepping to get the paint on before next week starts. Pulled 12 hours in the shed today and only stopped because the extension lead I was using blew out the power. The fusebox uses fusewire, so couldn't just reset it. As it was 2200, I decided I might as well go home for the night.
Jobs tomorrow:
Get more cutting discs for the grinder
Dive into more welding and get as much done as possible
Think about what needs seam sealed, prep some areas and decide what coatings I'm going to use under the stonechip.
Jobs done
- reinforced rear body mount areas with new metal
- also welded metal to rear of arches area
- welded in plates on rear of both seat pans
- test fitted new boot floor
Jobs tomorrow:
- Roger Fairclough
- Thank you received: 225
13 Mar 2021 10:22 #233704
by Roger Fairclough
Replied by Roger Fairclough on topic Giving the Jimny a birthday
I used to have an MoT testers certificate and I would have no hesitation in passing your welds.
Well done.
Roger
Well done.
Roger
14 Mar 2021 00:05 #233716
by Mike G
Thanks Roger,
That makes me feel a bit better about my precision bodging
. I should be getting better at it, I've done so much welding this past week.
. I should be getting better at it, I've done so much welding this past week. 2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
14 Mar 2021 00:24 #233717
by Mike G
Saturday 13th March,
Jobs done
Jobs tomorrow:
carry on fitting and welding the port arch plate
perhaps seal up the boot floor inside. Not sure what to use, perhaps tiger seal(?)
measure up metal for a rigid brace for front of vehicle during slam panel removal
Jobs done
- finished last two patches of welding on seat pans
- fitted and welded in boot floor
- welded in starboard arch plate and also welded outside seam
Jobs tomorrow:
14 Mar 2021 22:53 #233733
by Mike G
Sunday 14th March,
Jobs done
Jobs for tomorrow
WELDING and wire wheeling. I'm under no illusions now that I won't get much further than that in a day.
Jobs done
- tidied up workshop and ditched old templates and off cuts
- finished welding in port arch. Boot floor area welding now completed (finally!)
- bent some bits of metal to use for outer sil starboard side
- bent some bits of metal to use for outer sil port side
- welded in one of the starboard sil plates, two to go.
Jobs for tomorrow
- Thank you received: 1991
15 Mar 2021 06:44 #233736
Replied by Lambert on topic Giving the Jimny a birthday
It's looking close now, couple more hours with a wire wheel and that'll be ready. Good work that man.
Time to create page: 0.208 seconds
