- Thank you received: 1811
- Thank you received: 663
What diameter tube you using and wall thickness
- Thank you received: 923
Those lorry arches* are big and cumbersome to get in and out of the garage to try and test fit them, so I needed some plywood templates!
*don't worry the side with the white logo and pin stripes is getting cut off!!
Et Voila!
Hard to get a photo as the garage wall and racking is in the way, but it looks to be a good fit, just under the tube loop of the rear bed
And the front...
That'll work nicely too!
Note! Don't worry... they'll be fair bit of trimming to them yet! As shown earlier in the build thread -
jackonlyjack wrote: Looking good Pal
Hiya Jack... it's Cold Drawn Seamless Steel MSA FIA Approved - 44.45mm OD x 2.64mm Wall (MSA and FIA Spec)
Those arches will work well too
Yes...
There's 60mm x 60mm box section running down the side of the door edge over the hinges, that'll be capped off at the top with a hole-sawed hole for a length of tube to run down from the 'halo hoop' to the door bars, to protect the windscreen / body edge...
Then there's some 50mm x 50mm box running from the door bar edge to the front clip, shaped to run under the new bonnet edge...
And I've got the MIRROR GUARDS sketched up in my warped mind too :woohoo:
from above/from front and behind
wanting to weld a hoop round windscreen on mine
with holes in top of wings
marked up on your picture
Thanks
Jack
send them on whatsapp or facebook if you don't want them on here
If not, explain and I'll take some more...
I am interested in a front hoop too Jack, share the info please mate.
sniper
Tom "tube-bender" on eBay can bend up anything you want if you send him the dimensions...
Tell him I (dave-szookys) sent you
That was bent up and made by my Dad's steel fab' firm as I supervised...
