  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
12 Mar 2020 14:51 #219767 by X8GGY
Sat with a can of Stella last night (as you do) and placed my order...
Changed my mind last minute and bought two hoops to my size for the roofline guard, and a right angle bend to go around the fuel filler, and one of these -
to mount the top fairlead in...
For some reason when I entered the checkout on eBay it took 20% off my total, even betterer! :lol:
12 Mar 2020 16:38 #219773 by gv42
Replied by gv42 on topic Dave's la(te)st buggy build...
DO WE GET 20% OFF IN YOUR SHOP,,,,,,
  • X8GGY
  • Platinum Member
  • Platinum Member
12 Mar 2020 17:52 - 13 Mar 2020 14:23 #219778 by X8GGY
If you - or anyone else on here - order off me rather than through eBay I can always offer a discount ;)
Last edit: 13 Mar 2020 14:23 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
13 Mar 2020 15:24 - 13 Mar 2020 15:25 #219822 by X8GGY
Quick sketch of the revised hoop around the roof line -
I was going to the add some sheet steel in the back bit to hold the little fairlead I have.... but as I drew it I thought, no it doesn't need it, as the winch rope will run nicely over the hooped seamless steel tube... just like one of them Ultra4 buggies (Lambert) ;)
Last edit: 13 Mar 2020 15:25 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
15 Mar 2020 22:22 #219901 by X8GGY
I spent most of the day today welding...
The X strengthening in the rear of the cab...
Surprising how long it took!
16 Mar 2020 09:13 #219914 by sniper
Pretty heavy tube for a small welder.....
Remember to structure the weld on heavier jobs........ Root - Fill - Cap..... Makes for a stronger weld than just blasting it in and lets you run the set a little lower. Heat input is lower also which is always good news.
Looks great as always Dave, I look forward to seeing it in the summer.
sniper
  • X8GGY
  • Platinum Member
  • Platinum Member
16 Mar 2020 15:57 - 16 Mar 2020 20:24 #219929 by X8GGY
it's not a small welder ;)
I inherited it when my Dad retired... (he ran a steel fabrication firm - hence it's in my blood ;) )
And had the electrician wire a proper round plug for it when we built the extension....
Last edit: 16 Mar 2020 20:24 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
20 Mar 2020 13:01 #220087 by X8GGY
DIY tree scraper bars for the roofline just arrived!...
IS IT SUNDAY YET?! ;)
  • X8GGY
  • Platinum Member
  • Platinum Member
22 Mar 2020 16:52 #220148 by X8GGY
No eBay APP ID and/or Cert ID defined in Kunena configurationNo work on the buggy today :(
With all that's going on in the world at the moment, I decided to have a lie-in, went to visit my mum as it was Mother's Day, and then self-isolated myself in the garage making these -
Breather kit filter / ports and bracket for those with breathers that haven't got a snorkel to mount the end of the breather tube in, so these can be attached to the engine firewall to mount the end of the *8mm) breather nylon tube into... B)
Is it too early for a beer? (5pm)
22 Mar 2020 17:38 #220153 by Lambert
Beer o'clock yay cheers for the clearance to get on it Dave!
  • X8GGY
  • Platinum Member
  • Platinum Member
22 Mar 2020 22:37 #220166 by X8GGY
No eBay APP ID and/or Cert ID defined in Kunena configurationI didn't have a beer (then)... I went back into the garage and produced another batch... of these -
... smaller breather filter ports on smaller brackets B)
  • X8GGY
  • Platinum Member
  • Platinum Member
25 Mar 2020 22:19 - 25 Mar 2020 22:24 #220268 by X8GGY
... back to it today though!
I measured and cut the two rollbar hoops I'd had bent up, and then joined them together with some smaller diameter seamless tube inserts...
I then added the smaller 180 degree bend to the rear of it, and having cut and fish-mouthed the two stubs that come throught the Jimny's body rear hoop I placed the loop in place...
Looks a bit like a halo at the moment until all the other tubes are added! :lol:
You get the idea now? The loop is for tree scraping, to push branches out of the way when greenlaning, and the little rear loop is for...
... a mock-up with some blue builder's rope... so the rope that runs down in the tube under the passenger's (Alan's!) seat is static in the tube, a loop can be pulled out of the 'front' of the winch and up through the little loop on the back of the roofline, and a snatch block can be used in that loop of winch rope to either steady the buggy, or self-right it in the even of a "little lie-down" ! :ohmy: :lol: So as the winch spools in the rope is pulled back through the koop...
Pulled the front soft-top section back to test it fits nicely inside the roofline tree scraper and roof protection bars, and to bend the front mounts to suit... but time was ticking on by now, and the dogs needed a walk...
But then our youngest daughter appeared, with the dogs... her daily exercise trip in lockdown Britain, so I had another hour to play in my own self-isolation!... B)
So I marked a line down the centre of some 4"x2" rectangular box section...
And cut it in half! You can see where this is going! ;)
Side of the rear bed / waffle board holder!
Last edit: 25 Mar 2020 22:24 by X8GGY.
The following user(s) said Thank You: Max Headroom
Time to create page: 0.282 seconds
