- Thank you received: 923
We're taxed! Let's go 'laning! Errr.... one of these days
At least the tax is cheap(er) as it's a dead old Jimny!
And thanks for this fine forum, spurring me on, providing parts and advice...
See you in June! (Hopefully!)
- Thank you received: 116
Jalapeño, IISY?
Dave kindly hooked it up to a diagnostic panel -
And found the ECU thought the air intake temperature sensor (sensor on the airbox) was showing the incoming air was at 27 degrees C ?!
This was causing the engine to run briskly to try and cool itself down (water pump and viscous fan?) so I've just ordered -
A new sensor which should be here Friday / Saturday (I did check the BigJimny shop first! )
So that should fix that high tickover issue... and a bargain at a tenner...
Happy Days!
(I did wonder if the angle grinder sparks may have upset it when it was dangling in the engine bay?)
Just a new radator, cap, belts, plugs, etc to give the engine a bit of a makeover...
- Thank you received: 479
Knitting?maverick wrote: Your Wednesday's and Sunday's are gonna become boring soon.... what is the next project on the horizon?
Golf?
Nah! - maintenance inbetween trips
Sneaking out when the weather is fine
Learning to fly my drone and make some good videos
Still got some storage solutions to make for the Boogie...
Yes, I was nervous about having missed something simple / obvious, I was shocked when Dave said it had passed!Soeley wrote: Congratulations and well done, that is great passing first time without advisories considering all the work done
. I suppose it could be easy to miss/forget something?
- Thank you received: 1761
- Thank you received: 178
IISY...
