BigJimnyMeet 2024
- Thank you received: 178
26 Jan 2020 23:15 #217721
by gv42
Replied by gv42 on topic Dave's la(te)st buggy build...
looking good dave keep up all the good work and all the best too
- Thank you received: 923
29 Jan 2020 16:42 #217811
Bit more today...
I wanted to get the seats out before they got burnt with welding and grinding...
A little bit of work on them first, as where the original seat belt anchroages were on the subframes were in the way of the seats fitting properly... so I cut the mounts ff flush with the rails, and then drilled a new hole lower down on the rail and used some seamless tube as a spacer to get the seatbelt clips further out, and bolted them on with 12mm bolts washers and nylocs.. and then painted them...
And then bolted the seats back on firmly, and finally...
Popped them in one of our delivery cages to store behind the shop out of the way for now
I then turned my attention back to the already-cut bonnet edge, and experimented with some oval tube I had ordered and stored in the garage,,,
I cut slits in the back of it and manipulated it until it sat right...
And then..
Welded it in place and ground and sanded it back... there's a few welding distortions in the bonnet skin But it'll do! It's only an offroad buggy for some summer fun! And it will eventually be brush painted as it will only get scratched anyways!
Not too bad... some thick yellow JCB paint is standing by for the final finish!
And then..
29 Jan 2020 18:17 #217818
Replied by Riccy on topic Dave's la(te)st buggy build...
Good progress mate
30 Jan 2020 23:34 #217875
by kirkynut
Replied by kirkynut on topic Dave's la(te)st buggy build...
I've just re-read this from start to finish and realised I'd missed a few bits. You've really achieved quite a bit on this Dave.
I'm loving the sides where you've filled in the cut down doors and the Vector winch set up is coming along nicely.
31 Jan 2020 11:38 #217893
Thanks a Guys... it’s getting there slowly...
02 Feb 2020 17:54 - 02 Feb 2020 17:56 #217994
NOTHING today!
I was out Friday night to one of the wife's friends, and the husband had a full bar/pub in the back garden?! So we rolled home at 2am, and I then got up at 5:30am to do the papers, and worked until 8pm... Both of our daughters were home for the weekend before leaving together this afternoon for a few days in Barcelona, so I couldn't really abandon them and retreat to the garage...
So, a nice lie-in, family cooked breakfast, wave them off just after noon, so spent a couple of hours updating eBay listings, a nap for a bit, an hour in the hot tub, and about to have chicken dinner with the missus, now we're "home alone"!
A bit more relaxed about stuff at the moment
Dave
Dave
Last edit: 02 Feb 2020 17:56 by X8GGY.
09 Feb 2020 18:27 - 09 Feb 2020 18:30 #218231
Back to it today, determined to get it finished...
So today I welded up the driver's half-door, the new top to join the inner and outer skins, filled all the holes in the door, and some tube in the old window channel passed the mirror mount...
Attached to the inner skin too, they'll eventually be an aluminium chequer plate 'step' on the lower half of the door, and it'll fold into the inside to make a door panel too...
Hoping to get out in the garage again on Wednesday and enclose the rear of the cab cutoff...
Last edit: 09 Feb 2020 18:30 by X8GGY.
- Thank you received: 1761
09 Feb 2020 19:19 #218242
Very nice. You should be proud of yourself.
09 Feb 2020 21:11 #218248
Thanks! Should look better with some (yella) paint...?
10 Feb 2020 05:31 #218254
Everything should be yellow, by far the best colour!
10 Feb 2020 16:57 #218266
10 Feb 2020 17:58 #218270
Loving the chopped down doors
How will you open the door? small handle inside. Might I suggest the lever that used to open the fuel filler flap could be useful to you here?
Time to create page: 0.219 seconds
