BigJimnyMeet 2024
Ulysses
- Thank you received: 1761
23 Jun 2019 17:55 #210241
- Thank you received: 653
24 Jun 2019 15:31 #210261
Replied by jackonlyjack on topic Ulysses
Looks really good Pal
It will surely turn heads
25 Jun 2019 19:25 #210310
by Keithy
- OlaGB
- Visitor
27 Jun 2019 13:34 #210359
by OlaGB
Replied by OlaGB on topic Ulysses
Not sure what impresses me the most; the level of this build, or the fact that you did such a build while allready having one of the better builds from before!
Well done mate!
Well done mate!
29 Jun 2019 16:42 #210431
Thanks all for the kind words
I would be very interested in some of the arches you mention Keith, they look like they would fit perfectly. Ive had to cut bits out of these ones to make them sort of fit as they are lower at the front than the edge of the wing.
Day of wires today. Back lights specifically. Made up a new harness with some neat plugs and fed it in through the cable grommet beside the handbrake...
Connected up and nice and bright. The indicators are flashing like there is a bulb blown, so some sort of dummy load is needed to sort that I think. Work normally when on the hazard button, just not individually
29 Jun 2019 17:11 #210434
by RainerK
Replied by RainerK on topic Re:Ulysses
Or you get an load independent indicator relay. They are quite cheap out of China.
29 Jun 2019 17:16 #210435
Replied by Riccy on topic Re:Ulysses
Yes just seen the better relays, Ive ordered some resistors from amazon instead however... will see how they go
www.amazon.co.uk/Bulbs-Resistor-Signal-E...a-634680888943&psc=1
it is only the rear that is LED lamps so this gives me some spares as well
29 Jun 2019 18:01 #210444
Replied by jackonlyjack on topic Re:Ulysses
Them resistors will do just fine Riccy
If you can fit them to flat steel to transfer heat out of them
you could go as far as applying heatsink compound but probably not needed
30 Jun 2019 04:58 #210451
Replied by Lambert on topic Re:Ulysses
Ah. Now you're into the world of the dark arts, good luck!
05 Jul 2019 17:46 - 05 Jul 2019 17:47 #210674
Fitted the relays and they were making no difference, so read up a bit and realized I had wired them wrong, so need to look at that tomorrow.
Today however the windscreen man turned up to sort the cracked and chipped one in Ulysses. With the body shape flexing and changing slightly the screen had taken a turn for the worse. This guy, Martin, was recomended by the garage landlord so gave him a call. Quoted £110 fitted so ordered up on monday, fitted today. Great service and really good price as well.
Last edit: 05 Jul 2019 17:47 by Riccy.
06 Jul 2019 16:40 #210717
Compressor wiring and a few other odd jobs today including insuring and booking MOT. Insurance starts Monday and MOT on Wednesday. Plenty little jobs to do first.
Got the resistors fitted first for the back lights and thats solved the problem well. Next onto the compressor and switches. Had a fight getting this large plug for the switch wiring through the firewall so took it apart and went in easy.
Wires ran back to where the screenwash bottle used to be and connected up to the compressor. Bit of head scratching as to which wire was for what, but figured it out with the help of good old google
Then made a small plate to cover the area below the ash tray for the switches. works ok, but doesnt look the best. Needs Raptor painted! test run and its working ok, except the switch for the compressor is operating the other way up to the others so need to swap that around tomorrow. Compressor is a much older model than the one in J999MNY, but works fine. Is a lot more noisy tho...
Finally put the panel on below the windscreen and all the wipers back. looking nearer to finished now. The black pipe near the snorkel is for the diff/gbox/tbox breathers and loops back into the snorkel head. Need to fix it back somehow.
The following user(s) said Thank You: stiffsteve204me
- Thank you received: 305
06 Jul 2019 20:53 #210727
by sniper
Time to create page: 0.283 seconds
