Dave's Daily Driver Build Thread...
29 Apr 2016 14:30 #165990 by jackonlyjack
i like so many others are thankful that your blogs are so detailed :blush:
as us mortals need all the help we can get ;)
....keep the blogs coming..... :woohoo:
Jack
  • OllieNZ
  • Visitor
  • Visitor
29 Apr 2016 16:49 #165997 by OllieNZ
Replied by OllieNZ on topic Re:Dave's Daily Driver Build Thread...
Have fun fitting the rear corners ;) mine took a bit of playing to get right.
Where did you pick up your lhd cluster? I just dremeled out the blank to fit the bulb holder but it doesn't have the metal reflector just silver paint.
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
29 Apr 2016 18:05 - 29 Apr 2016 18:40 #166000 by X8GGY
No eBay APP ID and/or Cert ID defined in Kunena configurationeBay... .com rather than .co.uk
Being a LHD cluster it has a fog light hole in the bottom, with reflector...
Mine is a new aftermarket part from a seller in Italy -
£38.04 + £16.04 shipping
But there are european breakers on eBay for secondhand ones too...
Last edit: 29 Apr 2016 18:40 by X8GGY.
  • X8GGY
  • Platinum Member
  • Platinum Member
29 Apr 2016 18:41 #166001 by X8GGY
OllieNZ wrote: Have fun fitting the rear corners ;) mine took a bit of playing to get right.
Have you got a photo of yours fitted OllieNZ ?
And how do they attach? Do I need to keep any fixings off the old bumper?
29 Apr 2016 19:15 #166003 by jackonlyjack
  • X8GGY
  • Platinum Member
  • Platinum Member
29 Apr 2016 19:30 #166005 by X8GGY
No question is a silly question...
God, I hope so! LOL :lol:
I'm new to this too, I assumed they were all the same?!
Anyone? Put us out of our misery? ;)
29 Apr 2016 20:26 #166007 by j999pre
Same. Phew!
Grey pick up Jimny
  • OllieNZ
  • Visitor
  • Visitor
30 Apr 2016 05:57 #166017 by OllieNZ
Replied by OllieNZ on topic Re:RE: Re:Dave's Daily Driver Build Thread...
I'll stick a closer pic up later but there should be a couple in my Jimny thread. The only fixings I reused were a couple of the arch screws.
  • OllieNZ
  • Visitor
  • Visitor
30 Apr 2016 10:20 #166025 by OllieNZ
[IMG
[IMG
[IMG
Pretty self explanatory really. The screw through the side goes straight into the body. The 2 in the arch go into the existing captive nuts. I did have to grind/bend/tweak the metal arch extension to suit. A standard slitting disc works well on the fiberglass if you need to trim the corners themselves.
  • X8GGY
  • Platinum Member
  • Platinum Member
30 Apr 2016 11:46 #166032 by X8GGY
  • OllieNZ
  • Visitor
  • Visitor
30 Apr 2016 15:00 #166039 by OllieNZ
S200KYS wrote: Thanks Ollie! ;)
No worries :)
  • X8GGY
  • Platinum Member
  • Platinum Member
01 May 2016 18:16 #166089 by X8GGY
Bit more today!
Finished the bodylift off... First the steering shaft went back in, then...
Everything else was refitted...
And then drove the Jim out to clean the garage floor... lots of mud had fallen off!
Looking better! B)
Transfer Box out, ready for the Rockwatt Rocklobster to go in, and I'd sold the old mounts through the for sale section of this fine board ;)
Whipped the rear quarterlight windows out, drew round them and cut them out of the same tinted perspex that is going in the rear window of the fastback hardtop...
And then cut the rear window hole out!
Following the lines of the fastback as it narrows to the roofline...
Good rear visibility! B)
More in my own blog... ;)
Time to create page: 0.189 seconds
