Dave's Daily Driver Build Thread...
  • the_goshawker
  • Visitor
  • Visitor
12 May 2016 16:13 #166652 by the_goshawker
Replied by the_goshawker on topic Dave's Daily Driver Build Thread...
Give yourself a big pat on the back mate, that window job you did looks excellent. Your jimny looks mighty fine :)
  • X8GGY
  • Platinum Member
  • Platinum Member
  • but currently AWOL
12 May 2016 17:58 #166661 by X8GGY
the_goshawker wrote: Give yourself a big pat on the back mate, that window job you did looks excellent. Your jimny looks mighty fine :)
Thanks! :woohoo:
Some more bits arrived this week, from KAP this time...
Rear corner bumperettes -
No time to fettle and fit this week though :(
And the front bumper trim -
  • idiotmobil
  • Visitor
  • Visitor
12 May 2016 18:00 - 12 May 2016 18:02 #166662 by idiotmobil
Replied by idiotmobil on topic Dave's Daily Driver Build Thread...
Ya I like it such a simple but effective way to do it. Sorry but I mite have to steel the idea. the way I done them with window rubber etc was a right pain but this is much easyer
Last edit: 12 May 2016 18:02 by idiotmobil. Reason: Added
  • Daniel30
  • Visitor
  • Visitor
12 May 2016 18:03 #166663 by Daniel30
Replied by Daniel30 on topic Dave's Daily Driver Build Thread...
Thanks! :woohoo:
Looks good Dave does it have a plate to cover that exposed area under the bumper
  • X8GGY
  • Platinum Member
  • Platinum Member
12 May 2016 18:14 #166665 by X8GGY
Daniel30 wrote: Looks good Dave does it have a plate to cover that exposed area under the bumper
Not yet, need to stare at it for a while and work out what would look right... ;)
idiotmobil wrote: Ya I like it such a simple but effective way to do it. Sorry but I mite have to steel the idea. the way I done them with window rubber etc was a right pain but this is much easyer
You're very welcome to be inspired by my amateur attempts ;)
12 May 2016 18:17 #166666 by jackonlyjack
  • X8GGY
  • Platinum Member
  • Platinum Member
12 May 2016 18:22 #166667 by X8GGY
12 May 2016 18:30 #166671 by jackonlyjack
how they mount to the body
especially the rear corners as i was thinking about getting some
because i've have had to modify my rear corners due to rust
Jack
  • idiotmobil
  • Visitor
  • Visitor
12 May 2016 19:32 #166678 by idiotmobil
How much are they if you don't mind me asking
  • X8GGY
  • Platinum Member
  • Platinum Member
12 May 2016 19:32 #166679 by X8GGY
There aren't any fixings included...
I haven't any spare time this week/end so I'll probably be fettling and fitting next week now...
I just offered them up to have a look at how the looked and fitted, the front will need aligning and holes drilling to match original bumper mounting holes under the bonnet and where they attach to the front edges of the front wings; the rears mount to the back edge of the rear wings using the two big self tapping screws, and then to under the back door... somehow?
More soon... ;)
  • X8GGY
  • Platinum Member
  • Platinum Member
12 May 2016 19:34 - 13 May 2016 09:55 #166680 by X8GGY
idiotmobil wrote: How much are they if you don't mind me asking
www.kapsuzuki4x4.co.uk
£55 + VAT for the rear corner bumperettes
£140 + VAT for the front bumper trim
Last edit: 13 May 2016 09:55 by X8GGY.
  • OllieNZ
  • Visitor
  • Visitor
14 May 2016 06:59 #166764 by OllieNZ
Replied by OllieNZ on topic Re:RE: Dave's Daily Driver Build Thread...
OllieNZ wrote:
[IMG
[IMG
Pretty self explanatory really. The screw through the side goes straight into the body. The 2 in the arch go into the existing captive nuts. I did have to grind/bend/tweak the metal arch extension to suit. A standard slitting disc works well on the fiberglass if you need to trim the corners themselves.
jackonlyjack wrote: how they mount to the body
Jack
He wasn't kidding when he said "what fixings?" When I spoke to Darren @ KAP he said they usually glue them on.
Time to create page: 0.176 seconds
