× Are you building a Mud Monster or a Pavement Princess??
04 Apr 2016 18:34 #164864 by jackonlyjack
The following user(s) said Thank You: Paul_sterling
The topic has been locked.
04 Apr 2016 19:28 #164871 by X8GGY
fingers crossed for you Dave that's very unfortunate :blink:
Thanks Dan B)
maybe time to sort out the vac hubs and fit a 2 low switch ;)
Jack
Good idea Jack! B)
They are sat on a shelf in the garage pending sorting them out an refitting :laugh:
  • GraphicX
  • Visitor
  • Visitor
05 Apr 2016 02:47 #164879 by GraphicX
Replied by GraphicX on topic Dave's "S200KYS" Jimny 'laner Build...
wouldn't it be easier & more reliable to fit manual hubs over the vacuum jobs (is that what you're talking about) ??
05 Apr 2016 13:39 #164901 by Daniel30
Just asking the question :blush: but why would you want 2wd Low? Why would you not just use 4wd low?
05 Apr 2016 14:43 #164904 by Paul_sterling
usually for areas where you require low speed (so perhaps somewhere with tight turns or steep gradients) but have good grip (and so if using 4 Low you would wind up the transmission).
I used to use 2L on the second vitara in traffic jams, as it had manual locking hubs, so I could crawl along saving the clutch without winding the transmission up.
Paul.
Paul Sterling
2015 Jimny SZ4+, 1996 Toyota Hilux Surf, 2014 Mercedes W204 C-Class
(previously) 1994 Vitara JLX SE 16v, 2000 Vitara JX 8v
05 Apr 2016 14:55 - 05 Apr 2016 14:56 #164905 by Halford
Busta made a guide here a little while back :ohmy:
but its not for the VVT, the wiring is different on the newer electric switch AWD selection.
will need to find the 4wd connector on the transfer box and see what colour wires go into it. Or look at all the vacuum hub control stuff near the battery and see if any of the wires near the handbrake match the wires there.
I fancied it for traffic jams - or should that be Jim-Jams :dry:
Last edit: 05 Apr 2016 14:56 by Halford.
06 Apr 2016 15:27 #164958 by X8GGY
HooHoo :woohoo: My Transfer Box is on it's way back already, and due to be here tomorrow! B)
Thanks to our Redacted for the usual impecable service! ;)
Better fit it and go test it on Sunday then? B) :blink:
06 Apr 2016 15:32 #164959 by gusthegorilla
Well it would be rude not to, wouldn't it Dave ;)
Glad to hear you'll be up and running again. ...just can't fault the turnaround time :whistle:
I'm planning to live forever.....so far, so good !!
07 Apr 2016 14:23 #164997 by X8GGY
07 Apr 2016 14:24 #164998 by X8GGY
07 Apr 2016 19:11 #165012 by Laminak
Yes :woohoo:
It is a very good Adress :woohoo:
Ma Biquette
Jimny Cab 2001 1.3 SOHC - Green Filter - Snorkel - INSA TURBO 205/70 R15 - Jimnybits 2" lift kit
09 Apr 2016 09:44 #165074 by gaz3359
Good work as always dave look forward to bastards lane round 2 :cheer:
Time to create page: 0.285 seconds
Powered by Kunena Forum
