My 2011 Rebuild
12 Nov 2011 20:14 - 12 Nov 2011 20:14 #25624 by mlines
Shocks will be Rough Country.
Price is likely to be £360 ( 4x shocks and 4 x Springs) plus courier delivery.
Didn't get to work on it today as I spent all day FAILING to re-gasket my daughters boyfriends VW Golf sump (petrol 1.4 DOHC). An absolute pig of a job as two of the tiny hex bolts are in holes that are 9" deep and 1cm in diameter. Had to shop around for long, toughened Allen Keys, only to find one of the heads was rounded out. Could not get a drill in to drill out the head so gave up in the end. However, as I had left these difficult bolts til last, all the others were removed and the orginal seal broken. So I had to try and press sealant into the crack and tighten it all up, now it REALLY leaks oil! :(
However, to cheer me up this package arrived from Rob at Off-road Armory....
Attachment sized_IMGA0486.JPG not found
...a set of Spring Clamps to stop the rear springs dis-locating.
Last edit: 12 Nov 2011 20:14 by mlines.
  • supergaz
  • Visitor
  • Visitor
12 Nov 2011 20:32 - 12 Nov 2011 21:06 #25628 by supergaz
Replied by supergaz on topic Re: 22/10/11 - Replacing the Wing
I want some clamps! Maybe santa will bring me some!!!!!
It is great to see these added to the ORA website, I will get some once I have available funds.
Last edit: 12 Nov 2011 21:06 by supergaz.
  • Dutchjimny
  • Visitor
  • Visitor
19 Nov 2011 08:42 #26088 by Dutchjimny
Replied by Dutchjimny on topic 15/11/11 - Aaargh!!! it all goes wrong!!
Im going to fit my 3" in december very intresting how to ;)
  • g187eev
  • Visitor
  • Visitor
25 Nov 2011 08:25 #26539 by g187eev
Replied by g187eev on topic 24/11/11 - Removing the shock
Martin, we could draw and cut you whole new axle brackets. I would provide you with a set foc for you to test if you like. They would be 6mm steel throughout. would take approximately 7 days for me to draw, cut and post them to you.
RB
25 Nov 2011 13:27 #26549 by mlines
Rob,
That would be brilliant, I look forward to getting them.
  • g187eev
  • Visitor
  • Visitor
25 Nov 2011 14:41 #26554 by g187eev
Replied by g187eev on topic Re: 24/11/11 - Removing the shock
PM sent, I will design them to totally replace the factory radius arm brackets, so you will need to grind them off in prep for welding the new ones in place.
They will be 6mm M/S throughout, and I'll aim to get them to you before this time next week.
Just looking as a casing now, and they are quite involved, the panhard bracket and shock mounts are all integrated, so rather than just replacing one part I might as well re-draw the whole lot for you. That ok?... so you'll need to get back to just a bare axle tube apart from the coil saddles and the bump stop saddles.
RB
  • supergaz
  • Visitor
  • Visitor
25 Nov 2011 14:54 #26556 by supergaz
Replied by supergaz on topic Re: 24/11/11 - Removing the shock
Would it be an idea to raise the panhard bracket at the same time? Looks like another great product will be born!
  • g187eev
  • Visitor
  • Visitor
25 Nov 2011 15:09 #26558 by g187eev
Now that ain't a bad idea! Your call Martin. I'd just we could go up 50mm no problem?
RB
25 Nov 2011 15:11 #26559 by mlines
Sounds like an idea to me as well.
Although my failed bracket is on the Drivers side (Panhard Bracket is on the other)
  • g187eev
  • Visitor
  • Visitor
25 Nov 2011 15:13 #26560 by g187eev
I am going to draw up a pair of brackets ;)
Both LH & RH.
RB
  • chewy
  • Visitor
  • Visitor
27 Nov 2011 02:57 #26695 by chewy
Replied by chewy on topic 24/11/11 - Removing the shock
Hi. ive got a 1999 jimny, do you or your shop supply brake discks cos mine are Shot?
Please help cos i use mine as an electricians workhorse.
Hope to hear from you.
Mike
  • darthloachie
  • Visitor
  • Visitor
27 Nov 2011 12:25 - 27 Nov 2011 12:25 #26714 by darthloachie
Replied by darthloachie on topic Re: 24/11/11 - Removing the shock
chewy wrote: Hi. ive got a 1999 jimny, do you or your shop supply brake discks cos mine are Shot?
Mike
ebay :)
Last edit: 27 Nov 2011 12:25 by darthloachie.
