My 2011 Rebuild
27 Aug 2013 07:53 #81153 by kirkynut
Replied by kirkynut on topic Re: My 2011 Rebuild
So then Martin. The weather has been good over the last few months, in the main anyway. Where is Bigjimny at now?
27 Aug 2013 09:55 #81160 by mlines
Replied by mlines on topic Re: My 2011 Rebuild
The rear axle is back on and the Jimny is sitting on its wheels.
I was playing around with some different combinations so no photos at present as the shocks are on upside down and I didn't want to confuse anyone with the pictures.
The Jimny is away on holiday at the moment as we are moving house. Therefore I have moved it to temporary accomodation to save having to shift it on the day of the move.
When its back it needs the shocks putting on the correct way and the trailing arms need to be looked at as the axle is currently not sitting straight.
27 Aug 2013 19:16 #81204 by kirkynut
Oh dear - are the new brackets welded on in exactly the right places?
24 Sep 2015 19:06 #152501 by mlines
Whoa - a thread resurrection!
And has it really been 4 years!
See www.bigjimny.com/index.php/bigjimny-blog...-arb-air-line-repair
Any ideas on the way forward???
  • TomDK
  • Visitor
  • Visitor
24 Sep 2015 19:12 #152502 by TomDK
Replied by TomDK on topic Re: My 2011 Rebuild
drill and tap for a bigger fitting. Should be possible to find something that fits.
Or perhaps try chemical metal. When it's fully hardened it's possible to tap thread in it as well.
24 Sep 2015 19:16 #152503 by X8GGY
Replied by X8GGY on topic Re: My 2011 Rebuild
I'd just say one word... Rockwatt B)
24 Sep 2015 19:18 #152504 by X8GGY
Or, the place 'we' buy fittings for breather kits sell bulkhead connectors?
24 Sep 2015 19:27 #152505 by mlines
Replied by mlines on topic Re:My 2011 Rebuild
Hadn't thought of them, I think it needs to be 3/16 internal thread which may be a challenge
Sent from my Nexus 5 using Tapatalk
24 Sep 2015 19:36 #152508 by jackonlyjack
Replied by jackonlyjack on topic Re:My 2011 Rebuild
if you can wait a few hours i will ask the fitter at my new work place ;)
24 Sep 2015 19:46 #152509 by X8GGY
Replied by X8GGY on topic Re:My 2011 Rebuild
mlines wrote: Hadn't thought of them, I think it needs to be 3/16 internal thread which may be a challenge
Isn't the thread irrelevant? As long as the nylon air line from the compressor fits in one side of the bulkhead connector (push fit connector?) and then the copper line from the diff / actuator fits into the other side, you can drill for any size connector through the diff housing? No?
24 Sep 2015 19:53 #152510 by mlines
Dave
The copper tube is terminated in a flare end with a 3/16 brake pipe style male fitting on the end. You can just see it in this picture I did not include in the article. Devon 4x4 do the replacement fittings but as the casing tapped thread also appears to be missing/non-existent I think it will not seal correctly which is why I am considering my options.
24 Sep 2015 20:20 #152511 by mlines
Looking closely, it really looks like casing was never tapped. It looks like the fitting was installed with a hammer
Time to create page: 0.203 seconds
