Blown engine :-(
08 Dec 2023 12:54 - 08 Dec 2023 13:10 #252734 by yakuza
Replied by yakuza on topic Blown engine :-(
Swift engine distributor will interfere with your firewall most likely. On a Swift the Disto sticks out the side on the transverse mounted engine. but will go into your firewall when you put it longships.
The coil on plug models will fit easier but more electronics to sort out.
The Vitara with a disto will fit just fine as they are the same as the SJ engine but then you need an adapter for the gearbox and modifications for the oil pickup and engine mounts. (easy for you)
Or you can use your excisting cylinder head with the angled disto on the swift engine.
Also possible to do an aftermarket distoless ignition and blank off the swift disto.
If it is a twin cam Swift GTI the work might be worth it. but if it is a SOHC I would not bother.
G16 Vitara 8valve has an angled disto and a simpler wiring so mostly the mechanical challenges to make it fit.
But a SJ with 100 hp is worth it.
But sweeter running.. I would not know, maybe a 2001-04 m13 jimny and do the total swap, engine, wiring, dash cluster, gearbox everything.
Last edit: 08 Dec 2023 13:10 by yakuza.
08 Dec 2023 15:26 #252740 by lesgrandepotato
Replied by lesgrandepotato on topic Blown engine :-(
It’s a DOHC GTI motor, feels like the sort of thing that could have been factory in a kinda ‘stock plus’ approach.
The 8600rpm red line and 100bhp have some appeal as well
08 Dec 2023 17:25 #252742 by Phaeton
Replied by Phaeton on topic Blown engine :-(
With the handling of a Jimny?
08 Dec 2023 18:07 #252744 by Soeley
Replied by Soeley on topic Blown engine :-(
The Gen4 has 101bhp if I remember correctly?
08 Dec 2023 18:59 #252747 by Roger Fairclough
Replied by Roger Fairclough on topic Blown engine :-(
Yes 101 BHP @ 6,000RPM and 95 lbs/ft torque.
Roger
08 Dec 2023 19:33 #252749 by jackonlyjack
Time to create page: 0.189 seconds
