Blown engine :-(
- lesgrandepotato
- Elite Member
- Thank you received: 57
08 Dec 2023 09:21 #252723
by lesgrandepotato
Blown engine :-( was created by lesgrandepotato
Well that was an eventful school run. Much knocking and then no power. Ancillaries are free so it seems to be something deep and internal. I’d hazard its a big end issue.
B####r! I’ve got a trial on Sunday and an event on the 7th Jan. So decisions to make!
What fits, and what are we getting from where?
- Roger Fairclough
- Thank you received: 225
08 Dec 2023 10:12 #252725
by Roger Fairclough
Replied by Roger Fairclough on topic Blown engine :-(
Drain and drop the sump and then check for excess movement in big ends. Remove any offending end caps and check crank for wear.
Report back.
Roger
Report back.
Roger
The following user(s) said Thank You: lesgrandepotato
- lesgrandepotato
- Elite Member
08 Dec 2023 10:15 #252726
by lesgrandepotato
Replied by lesgrandepotato on topic Blown engine :-(
It is supposedly a rebuilt motor….
08 Dec 2023 10:52 #252729
Replied by yakuza on topic Blown engine :-(
Sometimes the G's throw a rod out the side when they die or the noises just get worse fast until they seize.
Any G bottom end can be made to fit. Most G engines can be made to fit.
I f you where in Norway I would say buy an adapterplate and put in a G16 from a Baleno/Esteem. Dependng on how easy it is to get hold of those engines now in yout country, approval, MOT and other parts availabilty.
I would do a 1.6 engine swap as the work involved is not too much when your engine has to come out anyways most likely.
- Roger Fairclough
08 Dec 2023 11:10 #252731
by Roger Fairclough
Who rebuilt it and how many miles has it done?
Roger
Roger
- lesgrandepotato
- Elite Member
08 Dec 2023 11:53 #252733
by lesgrandepotato
Unknown… I bought a part finished project. I’ve got options on Swift GTi motor G13b or an 8v 1.6 vit motor.
I’d like something that’s somewhat sweeter runnjng than the old 1.3 motor.
