Blown engine :-(
08 Dec 2023 19:38 #252750
Replied by jackonlyjack on topic Blown engine :-(
If I owned an sj I would go for M series vvt 13,15 or 16 mated to R7ME gearbox with a stand alone ecu
- lesgrandepotato
- Elite Member
- Thank you received: 57
10 Dec 2023 14:52 #252780
by lesgrandepotato
Replied by lesgrandepotato on topic Blown engine :-(
Righto. In the i’m going to crack on and do this at Xmas vein.
We have a g13b DOHC motor sat in the garage, with a loom, ECU and quite a lot of ancillaries.
The engine is a phase 2, so the angled dizzy cap trick should work.
Trying to sort out the exhaust manifold. Options are. Buy a specific manifold. That’s about 500 quid. No thanks!
Buy a g13b 4 branch performance exhaust and make an adapter plate with 12mm plate.
Buy a g13b DOHC turbo manifold and attach to that. Could allow for future turbo shenanigans….
Alternatively a jimny sports manifold? They have round ports which is good… matching the ports on the head (unlike the Sami performance manifolds)
But are the ports spaced the same? If so that could be an option that wasn’t available in period?
11 Dec 2023 07:34 #252792
Replied by yakuza on topic Blown engine :-(
Mazda 323 something distributor cap?
I think you still need to make a dent or cut out in the firewall.
not sure of the exhaust for the twin cam sorry..
The following user(s) said Thank You: lesgrandepotato
- lesgrandepotato
- Elite Member
11 Dec 2023 08:02 #252795
by lesgrandepotato
I’ve got the 323 cap and rotor.
After a day of decision making and research I’ve ordered a 4 branch for a Sami and some 12mm plate. None of the holes over lap so I’m going to fab up an interface plate to mount the header and blend the port shape.
Need to source a #17561-63B01 thermostat housing which should change from horizontal to side exit.
Then it’s on to the loom…
- lesgrandepotato
- Elite Member
11 Dec 2023 08:04 - 11 Dec 2023 08:05 #252796
by lesgrandepotato
Hopefully get some time tonight to pull the carb and ready it for sale. Anyone for a nearly new weber conversion kit?…
Then I’ll pull the head and drop in the spare DOHC and we can see what’s really going to be to do.
Last edit: 11 Dec 2023 08:05 by lesgrandepotato.
11 Dec 2023 12:27 #252800
I think mine is from an early swift something, not the twincam. (Will also fit the Baleno G16 for the same purpose)Need to source a #17561-63B01 thermostat housing which should change from horizontal to side exit.
Time to create page: 0.242 seconds
