My First ZOOK!
- CC Baxter
- Thank you received: 2004
- CC Baxter
- Thank you received: 96
CC Baxter wrote: I fitted mine under the rear seat squab and took the power from the back of the 12v socket. It synced after a 15 minute drive (I ignored the instructions) in low speed stop/start conditions. As long as you start with the dash in amber mode (not red) you should get a result. Once the car enters red mode it seems to involve a lot more messing about. I was told I had wasted my money on this device and should have pulled the plug on the TPMS module ( this I have not tried). The module is behind the dash on the right side near the A pillar if you fancy a go. Chris
Thanks Chris, very helpful.
What do you mean by red mode? The warning lights are all amber at the moment.
I’ll try again today with some fresh batteries and I’ll position the module by the 12v port. Maybe the module can be moved once synced, but for the purposes of syncing must be above a rear wheel.
CC Baxter wrote: Apparently TPMS warning light on is a fail but no light is a pass. Some very basic systems (and it's suggested the Jimny has this) just close down the system when you pull the plug. I must stress I have not tried this but if true it sounds a more convenient way of solving orange dashboards. If (and this is one for Martin) all world markets use the same wiring harness and not all markets get TPMS then there could be a way to pull the plug. The real spanner in the works is the BCM which could be different for various markets. Food for thought, Chris.
Interesting. The Spare Jimny is equipped with tpms evidently and is not keen on what I consider suitable cross country tyre pressure so if it is as simple as an unplugging then that could be the future. More research I think.
- CC Baxter
