Just purchased my first Jimny
04 Jan 2019 14:53 - 04 Jan 2019 17:23 #200005
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Just purchased my first Jimny
4 hours to do the front swivel bearings, inner axle oil seals, and rear wiper seals thingys. Used the blue waterproof grease. The wobble is now pretty much all gone.
I need to sort out the slide pins on the front callipers, seals are rotten and 2 were stuck. Freed them off, for now. 2 new disks wouldn’t go amiss in the near future.
Last edit: 04 Jan 2019 17:23 by adrianr.
04 Jan 2019 22:25 #200035
by adrianr
Pleased to report that the car now goes pretty much where it is pointed. Steering was so vague before. Improved after the tie rod end was replaced and improved much more with new swivel bearings both sides.
- Thank you received: 2001
05 Jan 2019 08:01 #200038
Replied by Lambert on topic Just purchased my first Jimny
When they're right Jimny's are actually quite responsive to drive and being light they change direction easily, it's just unfortunate that they're so sensitive to components wearing out.
The following user(s) said Thank You: adrianr
05 Jan 2019 21:50 - 06 Jan 2019 09:00 #200073
by adrianr
Took my first trip on some lanes near Betws Y Coed today. Very impressed with how the car performed so far. The hand throttle worked really well.
The suspension will need some work though. My 2-inch lift has extender brackets on the bottom of the shocks to make them longer and thick plastic blocks to lengthen the springs. So standard suspension made to look longer. Also, there was some odd clicking when doing the steeper descents, and articulating on the rocky bits. Sounded like a drop link failing on a car. Nothing obviously broken, however, taking a look around when I was doing the front swivels the other day the bushes in the radius arms look tired and perished, the drop links look well past their best. I stayed off the more technical lanes for the rest of the day to avoid any possible worsening. Did not notice it when on the road home.
I think an upgrade to a 2inch Trailmster comfort set of shocks and springs or possible Old Manu Emu (which I had on my Landcruiser and was very good) and refresh all the bushes would really help the car handle better on and off road. it was pretty crashy on the rougher sections.
I am looking forward to getting some new wheels so I can fit the 195/80 15 AT's to replace the Insa Turbos that are just too noisy. They do handle really well off road though but are vague on the road. The car is pretty heavy on fuel with such big heavy wheels and tyres.
Last edit: 06 Jan 2019 09:00 by adrianr.
08 Jan 2019 07:30 - 08 Jan 2019 07:39 #200159
by kirkynut
Replied by kirkynut on topic Just purchased my first Jimny
Wow, you don't mess about!
The tyres and lack of balancing (you can't truly balance these with weights) are likely to be what is causing your slight remaining wheel wobble.
If you get some standard steelies, how about painting them Old English White to contrast with the green? It's an idea I've had in my mind for a Jimny for a while where if I was to get another Jimny it would have to be green for me to do this. I just think it would be a good look.
I would go for the Trailmaster kit. The lifting blocks and shock extenders are just using your tired old components. New bushes will make a difference too.
Use the BigJimny Shop for parts. It's often cheaper, you know the parts are right and will fit and it helps fund the forum to keep it running.
Would you like me to move this thread to the "My Jimny" section, as it's becoming a proper thread?
Last edit: 08 Jan 2019 07:39 by kirkynut.
08 Jan 2019 08:25 - 08 Jan 2019 08:26 #200161
by adrianr
Hi Kirkynut
Thank you. I want the truck to be right so I can relax and trust it and enjoy it properly. Regular maintenance is easy after that. There are still a few things to tidy up where previous owner(s) have done quick rather than correct fixes/repairs/mods.
Yes, please move it to My Jimny section.
I agree Old English White wheels would look good. I'm watching a nice set of 5 matching alloys that end today. If I don't land those then steelies will be my next port of call and some white paint.
Once the new wheels and ATs are on I plan on selling the 8.5J alloys, and the Insa Turbos separately. I have already pre-sold the tyres that are on the alloys I am bidding on, in case I win them.
I cancelled my order with JimnyBits and ordered the swivel kit from the forum last week, and will buy through the forum when I can.
I agree about TrailMaster for the suspension, they also do caster correction bushes and am looking forward to getting the kit and installing it. I might in this instance order the suspension through my best mate who owns a 4x4 garage locally and is also a distributor for Trailmaster. It was his recommendation that put me onto the Jimny in the first place.
Last edit: 08 Jan 2019 08:26 by adrianr.
Time to create page: 0.228 seconds
