Just purchased my first Jimny
21 Dec 2018 10:22 - 21 Dec 2018 17:37 #199262
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic Just purchased my first Jimny
Resonance on accelerating
Pulled the driver's side headlight to see what the noise could be - turns out that 2 of the plastic clips holding the plastic wheel arch extenders on are loose. I'll get a dab of silicone on them in the New Year to quieten them down, meantime a touch of grease has made it better.
Last edit: 21 Dec 2018 17:37 by adrianr.
- Max Headroom
- Banned
- Thank you received: 217
21 Dec 2018 14:57 #199266
by Max Headroom
Yes - 'drumming' - another way to describe what I termed as 'panting'.
I've got the convertible Jimny and that black roof means the car gets unfeasibly hot inside when left parked with the windows fully up, so another little bonus particularly when there is a threat of rain and Im away from the car.
Replied by Max Headroom on topic Just purchased my first Jimny
adrianr wrote: they change the pressure sufficiently so you can sit on the motorway with the windows down a bit and not get that awful drumming.
21 Dec 2018 17:40 #199270
by adrianr
I leave the windows cracked down a touch when it is hot. The alarm doesn’t go off, people don't notice unless they look carefully and the car is not an oven when I get back in. My daily drive is a black Skoda estate with black interior so it gets toasty too.
22 Dec 2018 20:52 #199329
by adrianr
A little more work on some surface rust on the driver's side inner sill - removed loose surface stuff then treated with Hydrate 80. I will finish it off with some Bilt and Hamber seam sealer tomorrow.
Spent some time familiarising myself with the engine bay - been a while since I had a petrol engine to work with having run diesel since 2002. It is a nicely laid out engine and engine bay - great to have so much room to work around the engine bay. It's like a miniaturized version of my Landcruiser in there and underneath.
22 Dec 2018 21:39 #199332
by gv42
Replied by gv42 on topic Just purchased my first Jimny
hi, the hydrate 80 is very good,
23 Dec 2018 10:21 - 23 Dec 2018 10:24 #199341
by adrianr
Completed the dynax seam sealer application to drivers inner wing.
Tickover was occasionally lumpy. I suspected the EGR. Sorted that, so we shall see. Initial impressions are better.
Steam cleaned the combustion chambers. Warmed up the engine. Disconnected intake, set idle at 2000 rpm. Spray bottle initially with water and a touch of liquid soap, bicarbonate of soda and borax. Spray once every 4 seconds into the intake so engine note only drops slightly. Lots of steam from the exhaust. After 1/2 a litre which takes about 20 minutes, switched to clean water and did another 1/4 litre. Then take it for a nice hard run with lots of revs. I have wondered if the steam would help clean the cat as well, though I have never pulled one out for a look after doing this.
Ordered spare aux belts to carry in the car.
Last edit: 23 Dec 2018 10:24 by adrianr.
