The Jimny of the Yakuza
06 Jan 2017 10:47 - 06 Jan 2017 11:02 #176303
Or maybe swap to auto gearbox from another VVT?
More costly of course and need to get the interoir details..
Edit: No, too costly.. forget it.
Last edit: 06 Jan 2017 11:02 by yakuza.
06 Jan 2017 16:55 #176318
by Keithy
Replied by Keithy on topic The Jimny of the Yakuza
I'd say get the fat tyres on......but I can imagine how much the divorce would cost!
15 Mar 2017 12:34 - 15 Mar 2017 12:36 #179253
Gearing job has been kind of put on hold for a while.. Think best option is to change to expensive after market gears for low gear only in my existing transfer box. I think i like the highway revs as they are now. VVT manual is not your best option if you like to modify and put bigger wheels i guess.
In other news:
- MOT tomorrow. I have to put on my old legal 195/80 tires as 235's will not pass. otherwise should be ok.
- Come easter i will change to M16. low milage engine allready in my garage being stripped for its Liana past.
Pics will come.
Has anyone seen a build/how-to thread for M16 conversion better than this one:
www.auszookers.com/forum/viewtopic.php?f=17&t=30308
Or anything with pictures?
I think i've got all parts needed like rocker cover gasket, oil sump blue-silicone, oil filter stud..
Service parts and oil, and even a new clutch and an engine block heater element.
In other news:
Pics will come.
Last edit: 15 Mar 2017 12:36 by yakuza.
15 Mar 2017 14:09 #179255
by Keithy
I thought it was a straightforward conversion....swap your bits over and fire it up.
07 Apr 2017 16:19 #180028
Replied by yakuza on topic Re:The Jimny of the Yakuza
Putting this one:
Into this one:
Think I got it mostly sorted out and well planned.
It is a M16 from a '08 Liana going into my' 05 Jimny.
Into this one:
07 Apr 2017 16:53 #180033
Replied by Riccy on topic Re:RE: Re:The Jimny of the Yakuza
Thats exactly the same swap ive just done (M13VVT to M16VVT), except my 1.6 engine came from a swift sport.
Its pretty straigforward as Kiethy says, only problem i found was the water pump rear outlet wouldnt swap over, so i had to get a length of flexible rad hose to link the pump to the bottom of the rad.
The 1.6 liana throttle body fitted straight onto the jimny inlet manifold also (no grinding needed).
Riccy
Riccy
Time to create page: 0.220 seconds
