WAS DIRTYDOGZ JIMNY(SOFT TOP)
- Thank you received: 210
05 Dec 2011 11:16 - 07 Jan 2014 12:19 #27296
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: DIRTYDOGZ JIMNY
Fitted my roof spot light bar on the jimny at the weekend so here are some photos.
The bar is a mont blanc which came off my old fiat punto 5 door, and the spot light are ring from halfords.
Remove the plastic strip on the roof and the plastic cover on the inside and drill an 8mm hole in middle of the gutter slot, you can use an 8mm unistrut spring nut in the gutter slot.
Do not over tighten the nut and bolt has the roof as a double skin.
Use silicone sealant to seal the nuts and bolts.
You need to earth the spotlight to the car body.
2002 JLX Soft Top
Last edit: 07 Jan 2014 12:19 by dirtydogz.
- renard38
05 Dec 2011 18:32 #27318
by renard38
Replied by renard38 on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
good job
- myers647
07 Dec 2011 20:58 #27503
by myers647
Replied by myers647 on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
hi mate the spots look good does it fit in the gutter bit,I'v got the removable hard top one. I fitted a stick on light pod but i think im wanting a bar like yours to be honest. I just didnt think you could get a bar to fit a convertable.?
Thanks
James
Thanks
James
10 Dec 2011 18:27 - 25 Jul 2013 21:40 #27802
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
Yes l know what you mean
but l had the roof rack so decided to have a go :dry: and if it didn't work, l only had to filling two holes in the gutter slot.
All wired up and working.
Ok roof light working with my main beam,85 trigger go from the relay to the ACC on the switch, power on the switch go to the red wire on the back of the headlight plug, l'm happy now at last.
I wired it up the same as in this relay picture, and just add a live from the relay fuse to the ground on the switch, to make the switch light up.
2002 JLX Soft Top
Last edit: 25 Jul 2013 21:40 by dirtydogz.
17 Dec 2011 10:02 - 08 Apr 2012 12:39 #28422
by dirtydogz
2002 JLX Soft Top
2002 JLX Soft Top
Last edit: 08 Apr 2012 12:39 by dirtydogz.
17 Dec 2011 14:13 #28436
by Halford
light bar looks good
looks like a bit of lean on the blue Jimny :dry:
Replied by Halford on topic Re: DIRTYDOGZ JIMNY(SOFT TOP)
Time to create page: 0.231 seconds
