WAS DIRTYDOGZ JIMNY(SOFT TOP)
  • bertbuckie
25 Apr 2011 05:52 #15441 by bertbuckie
Replied by bertbuckie on topic Re: DIRTYDOGZ JIMNY new shock
a disco classsic ?
  • Fingers
02 May 2011 15:08 #15773 by Fingers
Replied by Fingers on topic Re: DIRTYDOGZ JIMNY new shock
thanks your all your advice dirtydogz
much appreciated.
You've done well;)
02 May 2011 15:45 #15776 by dirtydogz
That's ok mate good luck with your JIMNY lets see lots of photos as you build it.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
  • Nelson83
03 Jun 2011 16:45 #17278 by Nelson83
Replied by Nelson83 on topic Re: DIRTYDOGZ JIMNY new shock
is there any chance you can post a few pics of the brackets you made to fit your A bar on dirtydogz? Did you need to do any welding? Im after one, and if its a case of making a few brackets, then im might give it a stab and follow your lead with one from a later jimny :-)
03 Jun 2011 17:40 - 31 May 2013 22:42 #17279 by dirtydogz
Hi Nelson83
The brackets are from build base or wickes about £4 each.
No welding just bolt on.
This is the bracket l used but not from screwfix.
www.screwfix.com/p/heavy-duty-angle-brac...3mm-pack-of-25/69361
Hope this helps.
DIRTYDOGZ.
Last edit: 31 May 2013 22:42 by dirtydogz.
The following user(s) said Thank You: Nelson83
  • Nelson83
03 Jun 2011 19:09 #17290 by Nelson83
Guessing the big bolt with the washer is the orginal mounting point and the two smaller bolts are the ones that youve had to moddify to fit? Looks fairly simple to do - dont suppose you have a link to your supplier at all :whistle: ;)
Time to create page: 0.174 seconds
