Engine not starting (G13BB)
05 Jun 2025 06:05 #260757 by yakuza
Replied by yakuza on topic Engine not starting
Ask Martin if he can supply the part.
Maybe the same cam as on the g16?
My Baleno '99 have this sensor.
Because of me living outside britain making freight and currency costly, I have also used partsouq for genuine parts.
partsouq.com/en/catalog/genuine/locate?c=Suzuki
05 Jun 2025 07:59 #260758 by enforcer69@gmail.com
Partsouq doesn't ship under 500$ order...
05 Jun 2025 15:58 #260763 by jackonlyjack
The following user(s) said Thank You: enforcer69@gmail.com
05 Jun 2025 21:07 - 05 Jun 2025 21:09 #260764 by enforcer69@gmail.com
Thanks to everyone who tried to help — I really appreciate the time and suggestions.In the end, it turned out to be a cracked timing sprocket — barely visible unless you're really looking for it.If I had spotted it earlier, I could’ve saved a lot of frustration and pointless tests.Hopefully this helps someone else down the line!
The crack was already visible at the time when I set the timing but I didn't paid attention to that area.
Last edit: 05 Jun 2025 21:09 by enforcer69@gmail.com.
05 Jun 2025 22:46 #260765 by fordem
Replied by fordem on topic Engine not starting (G13BB)
Has this been confirmed as the fault, has it been replaced and the engine now starts & runs?
05 Jun 2025 23:12 #260766 by enforcer69@gmail.com
Is pretty obvious, isn't it?
Any crack will lead to a "dirty" / incomplete signal fed to ECU.
I'll update when I'll get a new sprocket, of course.
Time to create page: 0.207 seconds
