Caliper stuck
29 Sep 2022 11:07 - 29 Sep 2022 11:20 #245199
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Caliper stuck
I would use a high temp thick grease on the runners.
Perhaps this (first image), I've not tried this brand myself though.
With regards to the carrier bolts, I've never had trouble getting mine off. But not sure copper slip would last long in there, unless it was also high temp stuff (second image)
Last edit: 29 Sep 2022 11:20 by Mike G.
29 Sep 2022 11:30 #245200
Replied by mlines on topic Re:Caliper stuck
Do NOT use mineral oil based lubricant on the carrier sliders
It causes the rubber boots to expand and jam the sliders.
Use a correct brake slider grease
Sent from my moto g42 using Tapatalk
- eddlane
29 Sep 2022 13:26 #245201
by eddlane
Replied by eddlane on topic Re:Caliper stuck
Thank you.
All I’ve got is copper slip (unsure of temp rating) and the maxima waterproof grease chap.
- Thank you received: 679
29 Sep 2022 14:32 #245202
Replied by DrRobin on topic Re:Caliper stuck
My caliper carrier bolts were very tight on one side, I had to use a 6 sided socket and a breaker bar to get it moving. If it was me I would put a thin layer of copper slip on the carrier bolts, the ones that were stuck and secure the caliper carrier to the hub. Copper grease is over 1,000C.
If you have a torque wrench put the new bolts back in to the correct torque and they should come out again.
I also put a thin layer of copper slip on the back of the pads, someone told me years ago that it stops the pads from rattling and I have done it ever since, as well it will stop the pad from rusting to the piston.
I am not sure what to use on the caliper slider bolts, mine weren't stuck, so just put them back in as they were.
Robin
Robin
- eddlane
29 Sep 2022 15:00 #245203
by eddlane
Thanks guys.
I got some red grease for the caliper sliders.
Off to the garage now.
- eddlane
29 Sep 2022 17:57 #245208
by eddlane
Replied by eddlane on topic Caliper stuck
Took me an hour but I got the other off with heat and smushing on a 16mm socket.
then I was heavy handed with excitement and sheared the gosh darn ABS bolt.
I’ll continue with the rest of the job but can someone advise how I fix it/what part I need when I get to that point?
gotta love cars and ambitious but under skilled mechanics.
Time to create page: 0.103 seconds
