Caliper stuck
- eddlane
03 Oct 2022 09:06 #245281
by eddlane
Replied by eddlane on topic Caliper stuck
Thank you Lambert!
That’s what I did in the end.
Job complete, test drive done.
I’ll be doing a new post/topic with things I have learned as a novice that other novices may find helpful.
Thanks again to all who helped, a great community.
- Thank you received: 676
03 Oct 2022 09:47 #245282
Replied by DrRobin on topic Caliper stuck
The amount of grease to put in has been debated a number of times. I worked grease in to the CV and around the kingpin bearings then smeared a bit round everything inside the knuckle. I made an estimate of how much I had put in then just added the rest round the CV.
As soon as you drive it will re-distribute it around and as Lambert says if you put too much in it will soon loose it past the seal.
Good work on getting back together this morning, a bit of an early start by the look of it.
Robin
Robin
- eddlane
03 Oct 2022 10:18 #245285
by eddlane
Thanks Robin.
Yeh I need it for work this week and this has taken longer than planned
A quick trip to my local mechanic with a 4 pack of Ale as a thanks for the odd tool loan and removing my sheared ABS bolt.
Again, thanks for all of your help specifically Robin. I’d buy you beer if you were close!
Time to create page: 0.394 seconds
