Rust behind head-lights access?
02 May 2019 07:00 #207097 by Scimike
Sorry about that, the rot is always worse than it initially looks in this area.
HOWEVER, keep the faith, it can be fixed.
Lambert got the OEM option in replacement of the complete panel. Someone has done it, if my memory is correct only a few spot welds and an easy fix, approx £300?? --- ask Martin.
Others have made their own in box section to replace the rot, I have seen pictures on this forum, i'll try and find them again for you. This also looked a good end result.
So yep forget it and enjoy the Jimny for a bit, can always be done when u feel like it.
The following user(s) said Thank You: Keirravn
  • Keirravn
02 May 2019 09:20 #207104 by Keirravn
Replied by Keirravn on topic Rust behind headlights access?
Cheers guys. New replacement panel would be nice and easy but it's for a w plate with a bad paint job so the cost would be hard to justify unless there was no other option.
I came across this solution on the forum. I saved the picture in case I can't find the thread again.
More details (once I refund it I'll ask directly) and similar solutions would be really helpful.
I have a welder and can do patch repairs no problem but I've very little experience with fabrication. Though I'll be giving it a go when the time comes :)
I've got my years ticket anyway. Fortunately this area is well hidden ...
  • Keirravn
02 May 2019 09:21 #207105 by Keirravn
Here -
02 May 2019 13:13 - 02 May 2019 13:14 #207116 by Scimike
Yep that's the one I had seen^^^^^^
Real nice fix and a better design than the original being nice and open, no water or rot traps.
When mine give up that's the option I will go for, you cant see it anyway once all the lights and plastics are fitted, so my pigeon poo welding will not be on show :laugh:
Last edit: 02 May 2019 13:14 by Scimike.
02 May 2019 16:56 #207120 by Riccy
That fix photo is from forum member 'Kiethy'. Talented fella with everything he touches ;-)
Have a look here for a more home-brew approach (for the poorly skilled of the welding world, like me :laugh: )
www.bigjimny.com/index.php/forum/18-build-thread/63372-ulysses
The following user(s) said Thank You: Keithy, Keirravn
  • Keirravn
02 May 2019 18:26 #207128 by Keirravn
Can't believe I missed that one! Tons of handy pics and a great thread to follow. Cheers for that :)
Time to create page: 0.107 seconds
