Rust behind head-lights access?
  • Keirravn
26 Apr 2019 15:25 #206716 by Keirravn
Rust behind headlights access? was created by Keirravn
As per title really. I've found the common corrosion behind the headlights, before I start so I know what I'm in for is there access from below or is the rusted area boxed in?
Cheers
26 Apr 2019 15:29 #206719 by jackonlyjack
The following user(s) said Thank You: Keirravn
26 Apr 2019 15:49 - 26 Apr 2019 15:51 #206723 by Scimike
You need to remove the front wheel arch liner to see the full extent of that.
The good news is it's easy to remove fthe liner, the bad news is that rust will more than likely extend down the rear of the box section. It's double skinned and traps water....and it's the water drain route for the assembly - dumb design.
But if you have a welder it can be fixed...
Last edit: 26 Apr 2019 15:51 by Scimike.
  • Keirravn
26 Apr 2019 21:03 #206742 by Keirravn
Replied by Keirravn on topic Re:Rust behind headlights access?
Daaaaaaammm.
Cheers guys. I do have a welder and metal sheets here so it's not the end of the world. But it is annoying as I already spent some time welding the rear of the vehicle and thought I was about done with the repairs. Ach well. I'll get in about it next weekend
  • Keirravn
01 May 2019 22:14 - 01 May 2019 22:15 #207088 by Keirravn
Discovered, as suggested I would, much more corrosion. I think it's terminal for both ends of the slam panel. I'm going to leave it right now I just slapped on a load of rust inhibiting paint to slow it down.
Later this year I'll tackle it. I'm thinking of cutting out the area around the body mount and welding in some new C channel or box section metal.
Pics and info from anyone who has done similar much appreciated :)
Last edit: 01 May 2019 22:15 by Keirravn.
02 May 2019 04:11 #207092 by Lambert
You can get complete new panels from the bigjimny store. Just drop Martin a message with what you need.
Time to create page: 0.098 seconds
