Rust behind head-lights access?
- Keirravn
7 years 6 months ago #206716
by Keirravn
Rust behind headlights access? was created by Keirravn
- Thank you received: 706
7 years 6 months ago #206719
Replied by jackonlyjack on topic Rust behind headlights access?
Boxed in pal
The following user(s) said Thank You: Keirravn
7 years 6 months ago - 7 years 6 months ago #206723
by Scimike
Replied by Scimike on topic Rust behind headlights access?
You need to remove the front wheel arch liner to see the full extent of that.
The good news is it's easy to remove fthe liner, the bad news is that rust will more than likely extend down the rear of the box section. It's double skinned and traps water....and it's the water drain route for the assembly - dumb design.
But if you have a welder it can be fixed...
Last edit: 7 years 6 months ago by Scimike.
- Keirravn
7 years 6 months ago #206742
by Keirravn
Replied by Keirravn on topic Re:Rust behind headlights access?
Daaaaaaammm.
Cheers guys. I do have a welder and metal sheets here so it's not the end of the world. But it is annoying as I already spent some time welding the rear of the vehicle and thought I was about done with the repairs. Ach well. I'll get in about it next weekend
- Keirravn
7 years 6 months ago - 7 years 6 months ago #207088
by Keirravn
Discovered, as suggested I would, much more corrosion. I think it's terminal for both ends of the slam panel. I'm going to leave it right now I just slapped on a load of rust inhibiting paint to slow it down.
Later this year I'll tackle it. I'm thinking of cutting out the area around the body mount and welding in some new C channel or box section metal.
Pics and info from anyone who has done similar much appreciated
Last edit: 7 years 6 months ago by Keirravn.
- Thank you received: 2005
7 years 6 months ago #207092
Replied by Lambert on topic Re:Rust behind headlights access?
You can get complete new panels from the bigjimny store. Just drop Martin a message with what you need.
