Rust behind head-lights access?
07 May 2019 07:33 #207478 by Bosanek
What would be the best preventive measure to apply to this area of a Jimny which has not yet developed rust in that area (in order to prevent the rust from developing at all)?
The following user(s) said Thank You: Keirravn
07 May 2019 08:40 #207481 by Lambert
Either an epoxy paint or as a minimum one of the wax type products.
  • Keirravn
07 May 2019 12:50 #207485 by Keirravn
Replied by Keirravn on topic Re:Rust behind headlights access?
Bosanek wrote: What would be the best preventive measure to apply to this area of a Jimny which has not yet developed rust in that area (in order to prevent the rust from developing at all)?
It seems to me that they rust from the inside out as the slam panel is not sealed.
Next to the engine mounts there's a drainage hole each side. I'd spray a bunch of wax in there
16 May 2019 09:33 #208105 by Bosanek
If they rot from the inside, then the application any rust protection material from the outside will mostly be in vain.
Spraying wax from those entry points near the engine mounts can definitely do no harm, but the question is if it is possible to properly reach those potential rot points from there.
Does it make sense to cut away some sections behind the head lamps in order to expose those inner rot crisis section in order to properly rust proof the area? However I suppose that leaving the section open would not be a wise idea in the long run.
16 May 2019 09:57 #208106 by Lambert
Not on a Jimny but a land rover I drilled drain holes in various strategic places in the chassis to help get access to blind sections with a wax spray but also to allow water to escape. The rear cross members of defender chassis are notorious for rotting. Same principle as the behind headlight on a Jimny.
18 May 2019 15:57 #208271 by Keithy
Epoxy paint then waxoyl inside....not wondering if it's festering now.
Time to create page: 0.110 seconds
