Gen 4 Front Grille Removal
05 Nov 2020 08:55 #229697 by Roger Fairclough
Start at a corner and pull hard. Yes it will probably make some noises but if you want the grill off you must persevere. I will assume you have released the clips that you use a small screwdriver to lever the screw out!
Roger
  • Matt5141
05 Nov 2020 09:16 #229699 by Matt5141
Replied by Matt5141 on topic Gen 4 Front Grille Removal
I have released the clips under the bonnet and the 90° ones at the bottom of the grille, shown in the pictures in the previous replies. Trim clips were mentioned as well but couldn't figure out how to get to/remove these. Do these also need doing before pulling?
05 Nov 2020 10:28 - 05 Nov 2020 10:30 #229700 by lookonimages
After 90 clips and 2 under bonnet you just have to pull. Start at lower corner and pull towards you. The clips will release itself. Work al round till you get to bottom again.
Found that starting at bottom where 90 degree clips are you have more of a hand hold there.
Last edit: 05 Nov 2020 10:30 by lookonimages.
The following user(s) said Thank You: Matt5141
06 Nov 2020 21:08 #229757 by crash486
Replied by crash486 on topic Gen 4 Front Grille Removal
Lower black clips rotate through 90 deg, upper push clips, then the very tough white clips. I started at the top near the headlight. Yes , I thought I'd break the grill but I didn't. Good luck.
  • Matt5141
06 Nov 2020 21:25 #229758 by Matt5141
Where are the white clips?
26 May 2021 07:03 #235375 by 1tamad
Replied by 1tamad on topic Gen 4 Front Grille Removal
HELP! I'm stuck with the top of the grill. The grill is held fast by something on top of the 'S' in the middle and won't budge. I'm afraid to break it.
Time to create page: 0.707 seconds
